nitrous oxide gauge question
Okay my intention was to run two bottles on the deck (most likely 15lbers) with a Y into one 4AN line.... then underneath the carpet near the passenger side seat get a "T" fitting with two 4AN sides and one 2AN size (the 2AN will run to the back of the gauge) and the 4AN will keep going to the engine compartment to the nitrous solenoid for the direct port....
Okay so now that I've laid out my "intentions" what is the legality of this???? I planned on running the mechanical nitrous pressure gauge but i'm not sure if NHRA rules will allow it cause if the gauge exploded you'd technically have nitrous spraying out of the gauge into my face.... Will I be FORCED to use the electrical pressure gauge or just put a gauge on the bottles and be unsure of what pressure i'm purging down to???? I want to run the gauge up front so when I'm staging I can purge the system down to 950psi to avoid blowing my **** apart......
not too tough to do... I actually used the stock plate that holds the stock speedo, odometer and all the stock gauges. stripped it of all teh electronics, drilled the holes i needed with a hole saw and then upholstered it using speaker enclosure material with spray adhesive..... worked pretty nice and blended pretty easily. I was expecting some wrench throwing but it never turned out like that
hell now that I think about it I'd probably have the added 70 bucks (the autometer is like 85 and dyno tune is 150) in the T-fitting, the extra line, and extra fittings to run the nitrous up to the gauge.. not to mention the nitrous I lose after relieving the pressure when done racing.... didn't think about that fact...
