Wide band users come inside.
My buddy used one on his boosted lightning. I have the 02 bungs in my exhaust.........that would work great for the wide band. But I don't know what would be the best one to get or how hard it would be to install?
Any information would really help me in my quest.
Thanks
Well when I went to get the car dyno tuned for the nitrous kit I installed, the guy just hooked up the 02 sniffer in those holes. When he was done he just plugged them with some fittings that he had. He still has the 02 sensors though.
So I figured I might be able to do what he did, but with a wide band.
I was thinking of getting an fuel pressure gauge to go with the wide band commander and some how incorperate them into an a-piller gauge type setup.
I've seen them like that and they look really clean! I don't know how difficult it would be though!
Dean at DynoTune sells it in a kit with a gauge. I use one sensor to feed my Dynotune gauge
then I use an output from both sensors into my logging software cable.
PM me if you have more ?
What do those gauges monitor? Obviously the A/F, but what else?
Good luck.
Good luck.
That was the only reason I was going to do this. I didn't want to have to drill and weld another bung when I got two that will work.
The older AEM units only read down to 11.1:1 so if you get one, be sure to get the newere "6 in 1" kit that reads 10.0:1 to 18.0:1.
Charles
On the pillar right now is A/F (right bank) on top and fuel pressure below that. On the console in the swicth center and nitrous pressure to the right. The pod is autometer. I could not get a triple pod for my year so the new set up will be, A/F (left bank) on top and A/F (right bank) on bottom of the pillar. Then I will relocate the fuel pressure and switch it from a round gauge to a rectangular one and have it recessed in to the console to the left of the switches, in front of the shifter.
