upgrade fuel pump
Old Aug 22, 2006 | 04:37 PM
FASTCAMAROMAN's Avatar
Default upgrade fuel pump
what do most guys use to upgrade in-line in-tank what brand etc?
Old Aug 22, 2006 | 05:35 PM
Chris@NitroDaves
Guest
Posts: n/a
These are both for Camaro and Firebird applications and will support roughly support 650rwhp
Part # F99-FPKG2
Racetronix Fuel System w/ 255 LPH High-Pressure Fuel Pump and Series II Plug-&-Play Wiring Harness (includes chassis ground & booster pump plug-&-play option), 1999-2002 LS1 F-body w/ plastic fuel module (bucket) & Plastic gas tank $249.99
http://www.nitrousoutlet.com/catalog...product_id=966
Part # F98-FPK2
Racetronix Fuel System w/ 255 LPH High-Pressure Fuel Pump and Series II Plug-&-Play Wiring Harness (includes chassis ground & booster pump plug-&-play option), 1998-1999 LS1 F-body w/ metal gas tank $249.99
http://www.nitrousoutlet.com/catalog...product_id=967
We also sell Walbro replacement intank pumps that will support 500-550rwhp for $129.99
-Chris
Old Aug 22, 2006 | 05:40 PM
Default ..
i have a 98 so what do i need to get??
Old Aug 23, 2006 | 09:14 AM
Matt@HSW's Avatar
I'd suggest going with the Racetronix kit over the Walbro. the Racetronix is a direct replacement so nothing has to be modified and it comes with a hot wire kit, so all the electrical is "plug and play". We stock the racetronix pump kits, they ship the same day.
Thanks,
Matt
Old Aug 23, 2006 | 09:33 AM
02SS:ZEUS's Avatar
This stand alone system is what I plan on running with my nitrous. http://www.harrisspeedworks.com/shop...cat=373&page=1
Old Aug 23, 2006 | 09:35 AM
99Ws6TransAm's Avatar
Racetronix for the win. I had a walbro and it burned out within like 3 mnths. The racetronix is a easy fast, and simple install.
Old Aug 23, 2006 | 09:44 AM
Nitro Dave's Nitrous Outlet's Avatar
Depending on what is done to your car and how much you are looking to spray. You have not given us much info to work with.
Now if your set up will not be making more than 650hp this will work for you.
Part # F98-FPK2
http://www.nitrousoutlet.com/catalo...&product_id=967
Old Sep 24, 2006 | 11:30 PM
SILVERZZ28's Avatar
Racetronics uses Walbros
Old Sep 25, 2006 | 07:59 AM
I didnt specify any different . Its a modified walbro, and a ractronix kit will last you longer then a drop in walbro hands down.
Old Sep 25, 2006 | 04:18 PM
SILVERZZ28's Avatar
You said the racetronix pump last longer. Its the same damn pump. You can't moditfy the pump itself
