WOT or window switch, but not both?
Old Aug 26, 2006 | 06:40 PM
DragonsPhyre's Avatar
If I remember correctly it is red wire to power, black to ground, white to tach, and yellow to relay.. grey is not used. It comes with instructions.
Old Aug 26, 2006 | 07:23 PM
andypz28's Avatar
you mean the window switch comes with the instructions on how to synch it w/ the WOT switch?
i havent gotten the items in yet so i dont know...
Old Aug 26, 2006 | 07:57 PM
andypz28's Avatar
is there anyway this would not work?
http://i73.imagethrust.com/images/1R...d-msd-win.html
this guy told me it would have to be a 2 stage thing but that it wont work cuz the window switch will override the WOT switch even if both are wired like that?
Old Aug 26, 2006 | 08:44 PM
RASCAL_GTO's Avatar
my car currently has a Wot and window switch, only thing is i need to set my window switch, by anychance does anyone know how to set this window switch??
NO-00-7121 Digital Dual Window Switch (from nitrous outlet)
Attached Thumbnails WOT or window switch, but not both?-908windowswitch_main.gif
Old Aug 28, 2006 | 04:16 PM
tkz28's Avatar
use both
Old Aug 28, 2006 | 05:22 PM
andypz28's Avatar
both what?
Old Aug 29, 2006 | 10:25 PM
terry s's Avatar
Originally Posted by andypz28
also, what do you guys think about using a shift **** with a button?
that way i could hold it down to go and let go when i shift...
i guess it would take a while to get used to but i dont know...
I have a couple of suggestions for you. First I agree with some of the other members here. I do not think your installer has a clue as to what he is doing. If he messes something up and hurts your motor you can bet he will deny any responsibility. Second the vendors here are very helpful. I am sure if you tell one of them exactly what stuff you have they can help you get a correct wiring diagram. If you are careful and have any mechanacial ability you should be able to wire it yourself. Use the correct size fuses for your items, solder all connections to be safe and take it 1 step at a time and double check your work.
Yes you should have a FPSS, and a window switch as well as a WOT or TPS switch. You can put a push button on the gear shift if you want. I have one on mine. It is shuts the system off if I press the button. The reason I have it is that nitrous will just roast my street tires in first gear. So I hold the button down in first gear or anytime traction is not adequate. When I feel I have traction I let off the switch and it will spray.
DO NOT rely on a push button to act as your window or WOT switch.
