Tell me about the LS1 Plate systems
Old 09-01-2006, 11:20 AM
camaro98z28's Avatar
Well it looks like the plate systems give about 25 to 35 extra rated HP. I like that. I want to push about 600 rwhp and safely. Just don't know which one is better.
Daves is about $90 more than NOS. Does it come with more stuff?
Old 09-01-2006, 05:18 PM
Nitro Dave's Nitrous Outlet's Avatar
We stock both the NOS and OUR plate system.
The main differences you will find is the plate desighn
Our plate uses 5 nitrous and 5 fuel discharges that are desighned to spray across the intake throat.
The NOS uses one that sprays across the intake throat.
Our plate is machined to use the stock O ring gasket.
The NOS uses a paper gasket
Our plate has the inlet fittings facing towards the back of the intake.
The NOS inlet fittings are on the side.
Our plate system comes with jetting from 50-200 hp.
The NOS comes with jetting from 100-150 hp
Both systems can easily spray more. The NOS can produce up to 250hp and ours can produce up to 300hp with upgrading the hose from the solenoid to the plate.(cost around 24.00)
Let me know if I can help in any way..
Thanks
Dave
Old 09-02-2006, 11:12 AM
Slow Z28's Avatar
What about that dual stage plate? you guys still have that? and is it available for an f-body(i ask because the part number only relates to the corvette version)
does the dual stage kit come with the upgraded line or would that be an upgrade too?
