my Brute Force kit by HSW
Harris Speed Works lets you customize this kit however you want, you can choose the color of your lines, and all your fittings and choose the brackets for where the solenoids mount.
i got clear coated silver lines, with silver AN fittings for the nitrous side and red AN fittings for the fuel side with the AN to NPT fittings black, and i got the intake mounting brackets for the noids.
here are some quick pics i took, i still need to clean everything up a little bit and clean my motor some more.
here is where i mounted my bottle (this is my N.O.S. bottle, the kit comes with a 10lber with a pressure gauge too)
here are some brackets i made out of 1inch square aluminum tubing, it worked great
You call me saying you need me to come see something little you just slapped on the other day. Walk in the garage and
well holy **** where did that come from lol.Car looks great, glad your gauges came out good. Did you test out them 150 jets yet?
Matt
yesterday, the 150 jets went in, all i have to say, is holy **** *****
first and second gear went by like i was driving on ice.
i ended up hooking up a pressure gauge after i ran it and the bottle pressure was only at 800. i scaned my o2s on the run with the 150 and it was rich as hell, so i know if i get the bottle pressure up it will have some more in it.
and about the brakets, i only have them mounted on the one side, they just hang off the other side, thats why i used the square tubing, because it wont flex.
thanks for the complimets guys
Where'd you mount your switches?
i just drilled two holes hole in my ash tray, and mounted the arming switch and purge in there, thety fit nicely for now, im just waiting on one of daves switch panels to get shipped to my house
Matt
Matt
i love the fact you can customize the brute force kit how you want it.
it is also a great kit for the money, show me another dual nozzle kit that can make as much power as it is capable of producing whicle being able to customize it how you want it.
harris speed works definately has my business for my nitrous needs. i just need to get some cash together for a bottle heater
Matt
Thanks,
Matt
Are you pulling any timing out for this or no tuning at all??
mike
my only motor mods are a lid and some headers with true duals.
