help with bottle heater
Old Aug 31, 2006 | 07:42 PM
flash12t's Avatar
Default help with bottle heater
i have the dyno tune bottle heater. . i turned it on with no pressure and it heats up very fast but when i open the bottle it doesnt turn on i moved the screw all the way to the top and then all the way tight. . nothing. .even let it sit there maybe it took time to read the pressure. .bottle was at 900 psi please help is it a bad pressure switch or what. !@!
Old Sep 1, 2006 | 06:12 PM
flash12t's Avatar
t t t
Old Sep 3, 2006 | 10:05 AM
terry s's Avatar
If you have turned the screw to both ends of it's travel when under presure and you can't hear the relay click on you must have a bad pressure switch.
