What window switch do you use?
Old Sep 2, 2006 | 02:28 PM
99blancoSS's Avatar
Default What window switch do you use?
Not having good luck with window switches, what switch do you use?
Old Sep 2, 2006 | 02:52 PM
Robert56's Avatar
MSD
Robert
Old Sep 2, 2006 | 03:03 PM
00Vette's Avatar
I got the trick window switch. All the features it has are pretty damn cool.
Old Sep 2, 2006 | 05:55 PM
Wile_E's Avatar
I've got the old style MSD with the pills. WOrks fine for me.
Old Sep 2, 2006 | 09:17 PM
iamsickofitall's Avatar
i'm using the harlan window switch
Old Sep 3, 2006 | 12:21 AM
Ed Blown Vert's Avatar
Mallory
Old Sep 3, 2006 | 09:59 AM
terry s's Avatar
FJO wide band with built in window & TPS switches & will shut the system down if it gets too rich or too lean.
Old Sep 3, 2006 | 11:46 AM
SSDoubleK's Avatar
Wink
Get the Zex Traction Control Window Switch, real compact for a nice clean easy install, and will lock out any gear you do not want to spray in to hold you h.p. to the ground and save on our weak 10 bolts. The price of these has dropped, and can be found on Ebay. I had the MSD 8969 Digital Window Switch to big and did not work at all with my setup. Hope this helps.
Old Sep 4, 2006 | 10:55 AM
Bad N Black's Avatar
I just got the Timing Tuner from nitrous outlet. I'll let know if it works good.
Old Sep 4, 2006 | 10:58 AM
trigger1's Avatar
BMN switch
Old Sep 4, 2006 | 06:24 PM
BuBbABFP's Avatar
Dyno Tune.. Built in Window/TPS and has a cool feature to let you select what gear you want to spray.. il let yah all know when it goes one.
Old Sep 5, 2006 | 11:25 AM
stevethepirate's Avatar
tpp ftw
Old Sep 5, 2006 | 01:33 PM
can'tfindausername's Avatar
same here
Old Sep 5, 2006 | 01:36 PM
CamaroSS621's Avatar
NX but havent wired it up yet. but it looks sweet lol
Old Sep 5, 2006 | 03:02 PM
B.W.'s Avatar
same here
Old Sep 5, 2006 | 03:24 PM
Ramshaft's Avatar
I have the dig MSD box and i works great I have not had any problems with it. I also like the fact that all i have to do to adjust the spray is open the glove box and push a botton..
Old Sep 5, 2006 | 03:44 PM
2001z's Avatar
same thing here the msd with the pills and havent had a problem with it .
Old Sep 5, 2006 | 09:02 PM
Mr.6SPEED's Avatar
MSd digital best thing invented since chewin gum
Old Sep 6, 2006 | 12:43 AM
1BAD95Z's Avatar
I use the "Ellis" window switch "Ellis" see,s the tree come down and "Ellis pushes the button Unless "Ellis" see's the wall he does not lift the button until he goes through the traps at over 130MPH
BTW "Ellis" posting on Wife's new Laptop
Old Sep 6, 2006 | 12:54 AM
99blancoSS's Avatar
Is there nitrous on the laptop as well? I've thought about a button.
