Window switch not working. Spraying dead dig?
Old Sep 5, 2006 | 11:00 AM
99Ws6TransAm's Avatar
Default Window switch not working. Spraying dead dig?
This is something i had planned on not having to deal with..but it appears my BMN window switch is not working. I have a run with a friend today..and he wants to go dead dig. I have a 6 spd car..so getting off the line..and flipping the switch..is gonnna be somewhat of a task. Im jetted for a 125 wet shot..full bolt on motor, stock internals. Is it even safe to launch with the nitrous?
Old Sep 5, 2006 | 11:15 AM
andypz28's Avatar
i tried it this past weekend because i dont have the window switch hooked up yet.
i just had hand by the switch and flipped it after 3K rpms
Old Sep 5, 2006 | 12:03 PM
QUASAR's Avatar
Is it Rob??
The more important part is not spinning too hard in 1st and bumping the limiter. I know we set it high but still..
If I can find my harlan window switch you can borrow it. I will look when I get home. It just needs (+), (-), tach signal (same as your shiftlight), and it has a ground wire coming out of it that triggers the relay.
Old Sep 5, 2006 | 12:44 PM
Wile_E's Avatar
Do you have a WOT switch?
If so, I would just use that to activate it and make sure you don't bounce on the limiter.
Originally Posted by QUASAR
Is it Rob??
Yea. Me and Rob have talked about running a few times. I think we might wait till the Stenod/Varsity track day next week. Im almost positive my switch is wired that way John, and i still dont think its working. I'll need those tires if possible! Ill pick um up sometime this week if thats alright.
