recieved daves switch panel..
First impressions...the piece looks very nice, was 100 % satisfied with the appearance.
Installation..
Took hours to rewire EVERYTHING, I used all new wires trying to make it neat...when it came down to wiring the switching on the panel Ive found out the resistors soldered on from dave on the switches seemed very flimsy and I was quite dissapointed that even when I slightly eased on the connector one side disconnected. So now Im going to have to try and re-solder that.
The panel fit 110% and is very easy to get in and out of which is a plus.
The only complaint I really have is the resistors soldered on which you cant take off or the LED's will burn out, if mine burnt out because it got disconnected ( didnt use it yet) I'm going to be on fire. For those who just got them in and havent installed be very gentle around the resistor tabs!
Chad
Thanks for sharing your thoughts.. I always try to check and make sure that the resistors are soldered on good. But there is deffintly a chance that one came undone..
When you solder on your hot leads for the switch just solder the resistor back. The LED will still be fine.. If there is a problem I will gladly take care of you and send you another switch..
Sorry it took so long. The company we are useing for the switches is having a hard time stayoing caught up. We had to use a different supplier for the purge buttons on this last batch so we could get them out.
The company we are buying from is beefing up there order to stay cuasght up with us. So as soon as They can get ahead of what we are ordering that will be great.. Expecially since we will be releasing another two desighns in a week or two using the same switches..
Dave
Dave
Just make it clear my post was no way negative towards dave. They are a great company and I understand the Delay. You just know how all us car guys get waiting for our parts
Im watching my Yank SS3600 get put in as I type at my work right now, will finish wiring tommarow or saturday, Im going out to dinner tonight..its my birthday
Chad
