GTO dyno sheet on 150 shot
Old Sep 10, 2006 | 04:24 PM
johnnyrocket's Avatar
Default GTO dyno sheet on 150 shot
I just had my car tuned and I thick my clutch is giving up. I just installed a 12"in Center Force dual friction ( good for 600 hp ) last month.
What do you thing?
Old Sep 10, 2006 | 04:33 PM
Robert56's Avatar
Very nice numbers, now get some new times and get on the GTO nitrous list. As for your clutch, if it's toast, then think about the Textralia, it's a killer clutch which will handle all you can throw at it.
Robert
Old Sep 10, 2006 | 04:44 PM
BuBbABFP's Avatar
Very nice numbers man! i think u need a N20 tune..
Old Sep 10, 2006 | 10:41 PM
SmaknaSS's Avatar
Nice numbers for the mod's you got.
Old Sep 11, 2006 | 06:55 PM
speed_demon24's Avatar
Nice numbers, but why is the spray graph so wavey?
Old Sep 13, 2006 | 08:09 PM
Is that clutch slip? Thats what I was asking.
Old Sep 14, 2006 | 11:58 AM
Helmsdini's Avatar
how many miles are on that new clutch?
Old Sep 14, 2006 | 12:22 PM
srsnow's Avatar
My guess is it is a mixture issue the A/F ratio seems to have the same erratic pattern
Old Sep 14, 2006 | 01:25 PM
Wile_E's Avatar
That's part of the problem but what's causing that?
Is the car's tune for N/A or nitrous?
What's your timing set at?
What octane gas are you running?
Old Sep 15, 2006 | 06:57 AM
Helmsdini's Avatar
bottle pick up problems can lead to surging like that. Are you certain the bottle valve was fully open and the bottle is mounted correctly?
also, performance clutches are supposed to have about 800 miles of regular street driving on them before you really rip on them. I have seen alot of people glaze their clutches because they werent yet seated properly doing dyno pulls or blasting it with nitrous down the strip.
Old Sep 15, 2006 | 05:25 PM
I had the car tuned by Jermey Formato on motor first then he did one pull on 150 to see if it would lean out. The bottle was full so I don't think pressure was the problem. The bottle is mounted in the trunk in the right position. I was running 93 oct that day. I do have a 50 psi fuel pressure safety switch but I don't think it drops below 50 psi. He also told me to run race fuel when spraying and that the 50 psi switch would not cause a problem. The clutch has 1000 miles on it.
