Fuel system for 2 stage Dry/Wet?
Old Sep 13, 2006 | 06:27 PM
BTLFEDSS's Avatar
Default Fuel system for 2 stage Dry/Wet?
I'm going to be running a dual stage dry/wet.On the dry side which i will be spraying 100-120hp for the first stage and on the wet side 100-150 hp for the 2nd stage.Car is a M6 Hot Cam,Header car makes 353/365 on the motor.
42# injectors
Walbro Intake
Hot Wire Kit
Will this be enough fuel.I will also be running VP 104 for gas when spraying both stages
BTLFEDSS
Old Sep 13, 2006 | 06:57 PM
GM Muscle's Avatar
I think it's going to be close and a deffinate no go with a 120/150. With my set up, running a wet/dry 225 (crank rated) and a Walbro, I was loosing 8-10psi off the line and recovery was real slow. After I added the hotwire kit and voltage blaster it seemed better doing street passes but I'm still not totally satisfied with it.
However, I do jet the car on the rich side (according to some), and running 93/104 mix I never hurt anything running the walbro alone at the track. I'd give it a shot with a 100/150. Worst you'll do is hurt it.
Old Sep 14, 2006 | 12:07 AM
Robert56's Avatar
Get a return and reg at the rails, this will cure your supply issues, if ya have any. watching a fuel pressure gauge is the best method to see the shape of your system, or log for a/f and watch for going lean at high demand area. You may or may not be allright.
Robert
Old Sep 14, 2006 | 12:24 AM
chris.shea's Avatar
grabbin popcorn.
Old Sep 14, 2006 | 01:56 AM
CAT3's Avatar
Restricted User
Without a return regulated style setup, or a dedicated fuel cell for the wet I think you'll lose a lot of $ building another engine and fuel system. Bad thing to tap off the rail, more so when running dry / wet combo. GL.
Old Sep 14, 2006 | 09:19 AM
Matt@HSW's Avatar
I think at the very least you'll have to do a regulator and return, and chances are a boost a pump too to maintain fuel pressure. All of the 2 stages we have been doing latley have been using a stand alone on the wet stage, costs are around the same once you add in the BAP, regulator & fittings/hose vs the stand alone route.
Matt
Old Sep 14, 2006 | 10:01 AM
AzzHauler's Avatar
From: Richmond, VA Where fast cars, well......are hard to come by.
Matt
How long(#runs?) does the tank on the stand alone fuel cell kit you sell last on something around 100 wet shot? I was going to just run a 2nd wet stage off the rail with my dry, but that sounds like not a good idea the more I read. And nothing wrong with 110 fuel being used instead I suppose.
Old Sep 14, 2006 | 03:51 PM
Matt@HSW's Avatar
Quite a few, on a 200 shot around 7 or 8 until topping it off, playing it safe (keeping the top of the pump submerged).
Matt
Old Sep 14, 2006 | 05:06 PM
BTLFEDSS's Avatar
Matt i was actually looking at your standalone last night, definetley the route i'm going
Looks Like a great piece
BTLFEDSS
Old Sep 14, 2006 | 10:01 PM
Robert56's Avatar
We also now have a stand alone system, and no moving or relocating anything. Also, we carry fuel accumulators.
Nitrous Direct Stand Alone
Robert
Old Sep 15, 2006 | 11:25 AM
AzzHauler's Avatar
Robert
Is that a fuel solenoid included in the kit in the picture on the store page?
Old Sep 15, 2006 | 02:55 PM
GM Muscle's Avatar
Robert, where does that cell mount, and will you sell the cell alone? I take it that their is no kind of foam set up in it.
Old Sep 16, 2006 | 09:49 AM
Robert56's Avatar
That's the fuel regulator in the pic. At the link above is another pic with all items included and a good descript.
Robert
Old Sep 16, 2006 | 09:50 AM
Robert56's Avatar
Yes, the cell can be had by itself, at about half price, it's not on the site yet. I have an install pic I am trying to find to show install location.
Robert
Old Sep 16, 2006 | 10:44 AM
BTLFEDSS's Avatar
Robert i would also like to see the install pic
BTLFEDSS
Old Sep 16, 2006 | 10:59 AM
1 last 1's Avatar
Looks like a quality stand alone Robert, you may have just swung my vote to your side.
Old Sep 17, 2006 | 07:51 AM
BTLFEDSS's Avatar
ToTheTop
BTLFEDSS
Old Sep 17, 2006 | 11:32 AM
Robert56's Avatar
Went to the dyno yesterday and sprayed 235rwhp shot. Using the same system that BTLFEDss has (walbro, svo 42's, hot wire) and the addition of return and reg at the rails, no issues at all. Absolutely no lean spike with a 170 1st stg hitting, I mean, none, nodda, zilch. Also, no leaning out at highest demand, actually it was getting richer as approaching redline, and was rich all the way through run after 2nd stage hit. So, in conclusion, it works and I will be posting a new thread today with dyno sheet and full info on my new system.
Robert
Old Sep 17, 2006 | 01:59 PM
BTLFEDSS's Avatar
Great Robert looking foward to the new thread and aslo maybe a parts list
BTLFEDSS
