whats wrong
Old Sep 16, 2006 | 03:25 PM
02 z/28's Avatar
Default whats wrong
I just installed my timing tuner,I did not hook up the nitrous oxide features because Iam running a msd window switch.So i opened the box while the car was running and the green light stayed on while the red light flashes,is somthing wrong?
Old Sep 17, 2006 | 09:18 PM
02 z/28's Avatar
bump.nobody knows?Thanks for all your help lol.
Old Sep 17, 2006 | 09:59 PM
silverZ98's Avatar
i can tell you that when i frist got my timming tunner that i did the same thing as i had a msd window switch all ready. well it didnt seem to be working right, so i called full thortal the place th at makes them, and was told you chouldnt do that. and i need to use one or the other. so i did away with my msd, and used the built in window switch in the timming tunner. but before i did i sent the timming tunner back to be check out and they had to replace a chip in it as it was messed up from havent both wired up. after i got it back it has been working great for me over a year now
Old Sep 18, 2006 | 06:08 AM
02 z/28's Avatar
thanks man
Old Sep 18, 2006 | 06:51 AM
NXZ28's Avatar
Is this the Ramchargers Timing Tuner? I have one and I use a BMN window switch. It works perfect. My friend has one also. He has the MSD window switch and it works also. PM me on how you have it wired up and I will take a look at it.
Old Sep 18, 2006 | 04:26 PM
02 z/28's Avatar
pm sent.
Old Sep 18, 2006 | 08:35 PM
Bad N Black's Avatar
I just bought the full throttle timing tuner also. Your info help me out to. THANKS
