Spraying out of the hole
My first pass (shake down to see if every thing was working right) I heated up my 275/40-17 MT drag radials and lunched at about 3500-3800 rpms spun a little but not to bad then engaged the nitrous right when I hit 3rd gear every thing work how it should :thumbsup
My second run (trying to spray out of the whole or asap) I heated up the tires a little longer and lunched at 3800-4000 hooked up good not perfect but good when the nitrous engaged it bogged a little and took off.
My third run (spray out of hole again) I did the same burn out and run 2 tried lunching it the same as run 2 as well but this time when the nitrous engaged the car fell flat on its fast rpms would not go over 700rpm and by the 330' it was dead..... tried restarting it would work..... 2 min after letting it sit the car fired right up
My fourth run (same start as runs # 2 and # 3) the car did the EXACT same thing at is run #3
My fifth to eighth run I didn’t spray......
What could be the problem need help asap
Scott
Ricky
You need to check your stuff out and stop messing with it the second it doesn’t act right.
I’ve seen to many people go home on trailers because they wanted to try it one more time rather than just taking it home and looking into the cause of the problem.
Your situation sounds very similar to mine in the simple fact that you are getting too much fuel. You need a wide band like I do, so we can monitor the air and fuel in our setups.
I'm betting that there is an issue with your noid or lines causing too much fuel, not enough nitrous or no nitrous in your setup. Start with the noids and then check the lines........
Let us know how things go!
Good luck! BTW what did you run?
I never personally did that, but I was screwin with a buddy of mine, told him I was gonna run my motor to his spray and had one of my buddy's sneak in the trunk to open the bottle back up while he wasn't lookin in the staging lanes, well needless to say, at the top of second gear he's startin to come around me and I hit third and flip the switch and start goin slower, I was damnit, wtf!!! I get back and check the bottle, he only had it cracked open a 1/4 turn!
Oh and then I think the worst thing that i've had happen was launching off the t-brake on the 300 shot and the fuel noid hit, but the n20 noid stuck and didn't open, it was the most disgusting thing ever, the car just fell on it's face and died as soon as I let off the t-brake, I was like wtf! Then I realized what happened!
