What pistons/rods for n20?
i think your rods should be fine for 200. you would probably only need pistons. but while you are in there might as well replace your rods if you have money. expecialy if you want to shoot more
a few cars we have done with egle and have not had an issue but they are in the 500-600 range. my buddies stang we did was in the 900 range and first pass out this season with h-beem eagle about 500 feet out he put a rod right threw the oil pan, and bent 3 others!!!
as for pistions, i ran dimond with the big rings, hell fire rings, and coated the tops.
good luck
