Wideband question
Old Sep 21, 2006 | 08:12 AM
Matt@HSW's Avatar
Nope, sorry. You could try to sell your WS to recoup some of the $.
Matt
Originally Posted by waterbug1999
I bought a window switch so I dont need the timing tuner to do this: "Technical Specifications: Microprocessor Controlled | Turn on: 2000-5500 | Turn off: 5900-7400" as quoted on your site.
Is there a cheaper one that will just retard timing when N20 is activated and visa versa? Thats all I need.
Old Sep 21, 2006 | 10:09 AM
black_z's Avatar
Jody, you would probably only lose a few HP if you had him back off 2-3* of timing, Jeremy (HAULNTA) has his tune setup for nitrous, he could make a little more power NA, but the timing is backed a touch to keep it safe on the N20.
Old Sep 21, 2006 | 12:13 PM
terry s's Avatar
Hell, I cant weld and I guess "if" I go this route, I will have to take the headers off and take them to a shop.
I have longtube headers and no cats. This said, my 02 (one on each side) sensors/bungs are about 6/8 inches from the end of the header. So, your are saying just to place them where the pipe turns down and goes under the car and at a "2" oclock position instead of the "3" oclock position like the 02's are now??
Is there a kit that is acurate and can somehow use the exsisting 02's for a wideband set up? I really dont want to take the headers off "again".. Im running out of time to race up here due to snow will be here prolly next month! lol
As long as you are more than 18" from the exhaust valves any where in the header will be fine since you have no cats. I would just put them where you have the most room for access. And yes anywhere from 2 oclock up to 12 oclock is fine. I was very limited on space but mine ended up almost straight up (12 oclock). that is where I had the most clearance.
I know it is a pain to take the headers off but I think you will love the wide band. If you use the existing 02 sensors you have to go narrow band. This is not as accurate and you can't use the FJO unit. Also you won't have the lean-rich shut down feature for safety.
If you have no cats can you take the stock 02 sensors out and use 02 simulators? I'm not sure you would have to ask someone. If you can then you could put the new 02 sensors where the stock ones are.
I had the holes drilled and the double wall problem solved by squeezing both pipes together and gas welding the inner and outer pipes together where I drilled the hole. So when I took it to the welder he did not charge me. He just said come back when you have a bigger job. I can weld but the bungs were small & I wanted to be sure they were on good and I did not want to burn a hole in the pipe.
Old Sep 21, 2006 | 12:30 PM
waterbug1999's Avatar
Thats what I was kind of wondering myself? Does the wideband go where the stock 02's go and the car run off of that? Or do you need the stock 02's AND the wideband 02's??
Old Sep 21, 2006 | 12:32 PM
Yea, I think thats what I am going to do for now.. We are running out of time up here to race. I figured that I will get one last time and will spray the heck out if it! This might be a winter project.
Dusty, you going down to CFR in October when we all go?
Old Sep 21, 2006 | 04:05 PM
black_z's Avatar
Yes sir, probably going to camp out and party afterward.
Old Sep 21, 2006 | 04:56 PM
I dont think I will... I am going to have to rent a trailer for 60 bucks, therefore I will go and come back the same day.... Just racing this time..
I camped out at BIR (Muscle Car Shootout)for 2 nights and I partied more then i raced. IT sucked because there was 400 cars and I would race in the morning then have a few beers which turned into a 12 pack, and I was suppose to race in teh evening as well, but I was not going to race buzzed/drunk. lol
Had a good time though..
I am going to make this wideband a project ove rthe winter.. I might even work on a forged 383 and throw a 300 shot. I need to get a 12 bolt or a Dana 60 too!!
Old Sep 21, 2006 | 09:19 PM
terry s's Avatar
The wide band works by it's self. You can't run the car off those 02 sensors as far as I know. If you take your stock 02 sensors out and put the wide band sensors in their place you will need 02 simulators.
Old Sep 21, 2006 | 09:31 PM
I have them for the rear 02's.. Doesnt the car need at least the front 02's to run?
Old Sep 23, 2006 | 10:28 AM
black_z's Avatar
Technically no, you can run an open loop tune where your car runs primarily off the VE tables
Old Sep 23, 2006 | 11:22 AM
fotoboy's Avatar
JOdy, back off the timing 2 deg and leave it. youll forget what the car felt na once you start spraying! Im spraying 100 shot with 26 deg total with no problems, just make sure you run good gas, colder plug and if your rally nervous splash with some 110 from lakeville Mc stop
Old Sep 24, 2006 | 02:27 PM
  #32
Robert56's Avatar
Are you sure you need timing pulled? I run 24* with a 235rwhp shot and no problems. We carry the FJO, and some of the Innovetive products amongst others. they are in the new web site, which is on the main page of old site just press new online store for some insight. I just had the local muffler install my bung for 25 bucks, and I run the lm1, which can log your a/f and/or display actual or log into laptop and hide it away (and log mucho other stuff if ya want). I have a pic in my web site of it mounted on dash windshield.
Robert
Old Sep 24, 2006 | 10:17 PM
  #33
1MEANGTO's Avatar
You should not need to pull timing on a small shot like that. Just have gino scan your car while spraying and see if you have extra kr if you do look at how much you have and adjust your timing accordingly you'll never miss the little bit of N/A power.
Old Sep 28, 2006 | 12:10 AM
  #34
Well, I Put the TR 6's in and my plugs I pulled out (100 miles on them / Iridiums) were all black as hell.. So, i think its running really rich..
Looks like Ill just go with a simple LC-1 for now to trouble shoot this issue.
Old Sep 28, 2006 | 04:34 PM
  #35
terry s's Avatar
I don't know what the LC-1 costs but it will certainly help you get your AFR in the ball park. Just remember as far as I know it will not shut the system down if you get too lean. I have data logged mine and you would be suprised how much the AFR will change from one pull to the next and it will be different from one gear to another.
I would never have guessed this as long as the nitrous and fuel pressures stay the same I would have thought the AFR would stay fairly cosistent but it does not. Maybe the ECM is trying to compensate for the rich condition when spraying. If you have 02 sims then you might see more consistent AFRs.
I certainly could see the variance in AFR when reviewing the data log that you could not see as accuratly on the AFR guage.
