12volt power source for n2o kit?
Old Sep 26, 2006 | 01:26 AM
Oso SS's Avatar
Default 12volt power source for n2o kit?
I'm trying to figure out how to wire this new nitrous kit I bought, and the only thing I'm not 100% sure about is where to get this 12v power source... says the fuse panel... is there something in there that is labeled 12v power source?
I've got all the wiring figured out.. I just don't want to have to try to tackle this while I have wires going all throughout the car, I'd like to run everything, clean everything up and then get it settled into place permenantly.
Thanks!
Old Sep 26, 2006 | 07:09 AM
charlie c5's Avatar
You can use a volt meter, the main power into the fuse block is 12 volts as well. You are looking for this 12v source for your N2O relay, right.? For the 12v going to your arming switch you want a "keyed" 12 volt source, and for that the orange "12 ga." wire inside your knee bolster is perfect..
Old Sep 26, 2006 | 07:22 AM
WinSomeLoseNone's Avatar
I used the keyes on 12v line going into the Traction control button. Bottle heater, purge, window switch, and nitrous are all wired to the same 12v. Been working perfect for a year.
I believe the wire is red, maybe orange.
Old Sep 26, 2006 | 08:21 AM
Somebody09's Avatar
I used to the search to find mine...
Old Sep 26, 2006 | 09:28 AM
Wile_E's Avatar
Traction control is your best source.
Old Sep 26, 2006 | 09:31 AM
streetwarrior96's Avatar
I used the power block
Old Sep 26, 2006 | 09:49 AM
Matt@HSW's Avatar
Usually the pink wires are switched 12v sources, but double check.
Matt
