TnT install Please Come in and Help!
Old Sep 27, 2006 | 06:47 AM
JonSS_Tex's Avatar
Default TnT install Please Come in and Help!
First - where is a good clean looking place to mount the Msd window switch?
Second- where is a good place to mount the relay
Third- on the tnt kit the solenoids are mounted side by side on a bracket next to the intake\throttle body..........soooooooo if i install a purge kit where does the solenoid go cause i dont think it will fit below the nitrous one?
Id appreciate your help and any pics if you have em.
Also i would like to post some pics in my profile but dont know how.. .always says file too big....how do you adjust them to fit?
thanx
jonathan-----------------katy TEXAS
Old Sep 27, 2006 | 07:42 AM
Wile_E's Avatar
thanx
1- Glove box
2- under the dash where it can't be seen.
3- I'm not sure how the TNT solenoids and brackets are so I really can't tell you where to put the purge solenoid.
4- Use Windows paint to resize your pics.
Old Sep 27, 2006 | 08:19 AM
TRMIN8R's Avatar
Back when I had a purge, I just made a little bracket that mounted behind the TNT bracket.
Old Sep 27, 2006 | 10:33 PM
JonSS_Tex's Avatar
Thanks for those pics and suggestions. I like both set ups for the window switch, now I just have to pick one.
Old Sep 28, 2006 | 06:28 AM
Firechikn's Avatar
If you bought the tnt purge it comes with a long alum. addapter that screws onto the bottom of the nitrous solenoid and T's off a small braided line to your purge solenoid. Well I did not use the small braided line, I screwed my purge noid directly to the alum. fitting. It fits, close to the belt, but it fits. Even with the Dynotune dry noid screwed to the other side. hehe.
Old Sep 28, 2006 | 09:26 AM
TRMIN8R's Avatar
FWIW, I wish I would have put my window switch in the glove box.
Old Sep 28, 2006 | 09:30 AM
JonSS_Tex's Avatar
I dont know man, actually I decided on putting mine under the hood like yours. Is that the relay close by.
