700hp Fuel Pump?
Old Sep 30, 2006 | 01:29 PM
Speed Density's Avatar
hashtagBMW
Default 700hp Fuel Pump?
Hey guys,
Its time now to replace my stock fuel system, we already have braided lines and fitting planned out.
Now im just trying to find a reliable street/strip pump. The car right now makes 530+hp 500+tq, i will be putting a progressive 200 shot to it also.
I see that most guys are running Walboro, im thinkin thats what most of you will recomend too.
I was looking at the AEROMOTIVE A1000 PUMP , seems like a stout pump.
So, what pump?
Tony.
Old Sep 30, 2006 | 01:58 PM
Matt@HSW's Avatar
Yup, something like Racetronix/Walbro along with a stand alone for the N2O. The A1000 will require a sumped tank and if it sees any street time a pump controller too.
Matt
Old Sep 30, 2006 | 02:31 PM
TwoFast4Lv's Avatar
Using a Racetronix kit to get the numbers in my sig If I were to go more I would go with a stand alone fuel for the N2O.
Old Sep 30, 2006 | 04:49 PM
1BADAIR's Avatar
lt1's have a regulator on the rail.
I can't get my ls1 to make 600 spraying off the rail using the racetronics PNP. It drops 12 psi
Old Sep 30, 2006 | 05:37 PM
hashtagBMW
I dont have anywere near stock LT1, or anything that says LT1 except the Block and Opti. So I need a regulator.
Tony.
Old Sep 30, 2006 | 05:45 PM
1BADAIR's Avatar
just saying that the front mounted regulator helps alot over the intank ls1 unit
Old Sep 30, 2006 | 05:53 PM
hashtagBMW
Oh, in that case yea....
I had planned on gettin a front mount anyway.
Old Oct 1, 2006 | 12:19 PM
TwoFast4Lv's Avatar
I knew he had a LT1 It is not only the front regulator it is the higher pressure that is hurting you The higher pressure you use the less HP a pump will usually support I am running 48-50 PSI on mine with a factory regulator and 40Lph(at that pressure) injectors
Old Oct 1, 2006 | 01:55 PM
hashtagBMW
Im actually just thinking about gettin a Walboro or Racetronics for now, and then next season going ape **** on a Standalone.
Old Oct 1, 2006 | 02:33 PM
Noyzee's Avatar
8 second mod
I run this pump as an inline, its pretty affordable and it has not let me down for over 3 years! my car has no problem making in the 500 range on motor, and then my stnd alone takes care of 300+ worth of spray. not sure, but im pretty sure this can be used intake as well.
i got it from tom at Speed inc!
Bosch
Bosch 420L/hr Inline pump
Bosch supplied the industry's first fuel injection system with a high-pressure electric fuel pump in 1967 and has been the worldwide leader in innovative electrical fuel pump technology and design ever since. With Bosch, you are assured of state-of-the-art technology and superior, original equipment quality.
Has been in our project car and gone all the way to 720 RWHP without leaning out!
itemno description price buy
BOS420 Bosch 420L/hr Inline pump, with #10 in and #8 out fittings $349.99
Old Oct 1, 2006 | 02:34 PM
Noyzee's Avatar
8 second mod
find it here.
http://www.ls1speed.com/catagory.cfm...%20/%20Cooling
Old Oct 1, 2006 | 07:05 PM
hashtagBMW
What about a Weldon 600A?
