Who is spraying with out the drill mod??
Old Sep 30, 2006 | 06:05 PM
ls1amit's Avatar
Default Who is spraying with out the drill mod??
I am installing my new clutch within this next week and i plan on spraying a few months i just want to know if anyone is spraying with out the drill mod or if its a must do with n20. thanks
Old Sep 30, 2006 | 06:54 PM
chris2000ss's Avatar
I didnt drill mine,I havent had a problem with it...
Old Sep 30, 2006 | 07:53 PM
meatfoam's Avatar
What's your new clutch?
Why do the drill mod? Do you even know that the drill mod works?
Do you think that your car will need the drill mod, because your pedal will stick to the floor when WOT on the spray?
The drill mod is questionable at best. I spray just fine with a beefy clutch and nicely bled hydraulic lines.
Old Sep 30, 2006 | 11:51 PM
Robert56's Avatar
Drill mod is an old wives tale. A good pressure plate/disc is all you'll need.
Robert
Old Oct 1, 2006 | 01:10 AM
nostyta's Avatar
No drill mod and no problems here.
Old Oct 1, 2006 | 02:03 AM
andypz28's Avatar
no drill mod, stock z06 clutch, and it DOES stick to the floor after some runs
Old Oct 1, 2006 | 02:33 AM
02NBMWS6's Avatar
no drill mod here, no problems. if anything, upgrade your master cylinder.
Old Oct 1, 2006 | 04:25 AM
forgedbluess's Avatar
I had a budy with a stage 3 cluth, heads and cam car with a 150 shot and the clutch went to the floor after 3 passes but good luck.
Old Oct 1, 2006 | 10:53 AM
ls1amit's Avatar
yea im running a spec stage 3 plus so i guess alot of people run with out the drill mod thats all i wanted to see. yea i hear when it sticks its air in the lines when its not properly bled.
Old Oct 1, 2006 | 10:56 AM
flash12t's Avatar
sprayed for the first time at the track the whole way threw was fine but at the end of the run could feel the clutch wanting to stick . . im going to do it when i do the new clutch just to see if it helps . .
Old Oct 1, 2006 | 12:40 PM
2001z's Avatar
No drill mod never sticks to the floor after runs . Spec 3
Old Oct 1, 2006 | 12:44 PM
red fury's Avatar
RamPowergrip HD with 300series disk= no problems and no drillout mod
