Nitro Dave help with plate?
Looking at your airfuel. You can see where the nitrous comes in. The air fuel intsantly goes richer. After abvout a 1,000 rpms into it on the nitrous the airfuel is steadily droping going richer. It ends up about 11.0 or so. This is one reason why you are not making the hp gain you are looking for. Get your airfuel at 11.8.
Also you have a small window that the nitrous is working. Get it to where the nitrous comes in sooner.
If you want to be done with all your window switch woes ditch the one you have and forget the MSD and use this one.http://www.nitrousoutlet.com/catalog...product_id=964
Let me know if you have any questions.
Thanks
Dave
We suggest air fuel at 11.8
Bottle pressure at 950-1050 psi
Timming needs to be accurate.
Thanks
Dave
I am on to the tuning side like the Clinton on a intern
May take me a year or two, but I am snooping around all the tables soaking it in.
I didn't start it I just finished it
I tuned my car(NOT a plate) on a Dyno also and I highly recomend it to all. I was passing on what I my experiance was with a kit totaly cutom desighned for my car by Dave and his crew. it is a One Off system I can garruntee no one else has. Jetting was spot on.So knowing this I felt falrly confident that a system they sell a ton of would be pretty close right out of the box also once all the other variables were tuned in.
I also took the time to share my Dyno results in detail With Dave and the crew. I got 188 out of the 185 jets and 199-201 out of the 200 jets. Seemed fairly close to me
As for the window switches.
The window switch is sent you a link on is a completely sealed unit. It has a built in TPS activation and any gear lock out.
WE stock the MSD and this unit. THis unit is a much better built unit than the MSD.
Dave
Dave
Can you descibe how to read plugs?
Don't get your panties in an uproar.
Please take your negativety to another forum, or rather site.
Robert
http://www.dragstuff.com/techarticle...ead-plugs.html
The link below is to a spark plug forum where they can help you diagnose and solve your problem much better than most can here. There should be plenty of spark plug genious' on that site. You may just want to sign up and become a member if your going to stick with nitrous!!
http://www.dragstuff.com/phpBB2/viewtopic.php?t=22
I hope this information helps and let us know how it goes!!
I seen this in another thread ,maybe it will help you also.
