4K stall, what RPM to set activation switch.
If I was to spray out of the hole, what rpm's should you set it at?
If I DONT spray out of the hole and spray from 2nd on up, would it be the same RPM?
I know on spray, verters tend to "flash" higher then 4K (in my case), so should you set it a little lower or right at 4k?
Mine is set at 3K. I leave at 1400rpm and the kit comes on right when the nose lifts. I have a 4000 stall also. It does not flash it too hard. I can cut 1.5X 60' here in Germany on an unprepped track. It is basically just an airstrip.
i have mine set at 3000 with a 3500stall. i just activate the system when the car shifts to second.
i have only sprayed out of the hole once and it spun a lot but i flashed the converter instead of stalling it.
