spray
Old Oct 6, 2006 | 06:08 PM
z28boy's Avatar
Default spray
I need to know what type of nitrous system is the safest for a stock bottom end.It needs to be a easy install. Would like 100 to 125hp. I just put a th 400 in it and would love to see what this thing can really do. Any help would be great.
Old Oct 6, 2006 | 08:55 PM
sprydncamd ta's Avatar
i run the harris speed works brute force kit but that is a little to much for what you are looking for i would check out their dry kit all there kits are easily installed and you can customize your own kit with colored lines and other accessaries heres the link
http://www.harrisspeedworks.com/shop/home.php?cat=365
Old Oct 6, 2006 | 09:41 PM
z28boy's Avatar
is the dry more safe then a wet kit
Old Oct 6, 2006 | 10:47 PM
brad8266's Avatar
Neither is more safe than the other. It all has to do with the install, proper use, and having the right supporting mods..ie cold plugs, good fuel pump. They are both very safe on our cars when used right.
If youre gonna stick with a small shot, just go dry, its cheaper and a little easier to install as well as packing a punch.
Old Oct 7, 2006 | 07:48 AM
chris2000ss's Avatar
+1 for dry kit
Old Oct 7, 2006 | 07:54 AM
2001z's Avatar
+1 for the wet . I had to do it
Old Oct 7, 2006 | 11:08 AM
Robert56's Avatar
+1million for the dry as the safer set-up. This supported by the facts. Try to find someone who blew their intake and hood off running a dry hit, you will not. Now try to find someone who has done it running a wet hit, you will find some. So, dry is a great kit to use and can be set-up for bigger hits later when your ready, and you'll be ready after a bit spraying 100/125. Check out our pro dry kits, very complete and easy to install and produce the numbers and times. Now if ya want to go wet, which is actually very safe also, we have so many different kits to chose from check our new site out, home page at old site click New Store Open.
Robert
Old Oct 7, 2006 | 01:33 PM
for what your looking for i would go dry as your safe bet and if you wanted to go bigger you could always upgrade to a two stage
