setup opinions?
Old Oct 6, 2006 | 10:31 PM
camar0corey's Avatar
Default setup opinions?
Ok I'm thinking about ditching my zex box before I even get it installed. I originally was going to install a MSD 3 stage retard, a MSD window switch(one with pills) and the zex dry kit with purge. Also have a older style NOS remote bottle opener and NX bottle heater.
Well now I'm thinking instead of that whole mess I would use everything from the zex kit minus the zex box. Would this be hard to do? Could I use a nitrous solinoid from anybody? I'm thinking of running the FJO controller, but I don't know much about it, does this one have a WOT switch?fjo
It seems this would help me keep the 10 bolt alive and then I wouldn't have to wire in all these extra boxes. Also can the LT1 PCM be programmed to take timing out when the nitrous is activated? Any ideas/thoughts/opinons would be appreciated. Thanks. Oh yeah I think I want a newer type of bottle opener also, who makes the most affordable one of those? The older style NOS one you still have to open the bottle correct?
Old Oct 9, 2006 | 11:14 AM
ttt
I'm looking for a nitrous controller that is progessive, has a wot switch and window switch built in. Still wondering about timing retard options also, I don't think I like what I read about the 3 stage retard in the instructions. Can I have the PCM programmed to retard timing when using nitrous? Need help. Going to be a dry setup also, should I use a NOS or a NX solinoid?
Still need opinions on a remote bottle opener also.
