hypertech w/nitrous
Old Oct 10, 2006 | 12:01 PM
stdjsw311's Avatar
Default hypertech w/nitrous
ok i bought a car that was suppost to have a hypertech program in it. i dont know what the is really supppost to mean but is there a way to reset the computer or get rid of it??? the main question is i am trying to run nitrous and i am not sure if the hypertech programmer adds timing to the car or not???
Old Oct 10, 2006 | 12:31 PM
Matt@HSW's Avatar
They usually add a bit of timing, but it would depend on what settings were used. Two ways to reset it, one with the hypertech whice originally flashed it or take it to a dealer and have them flash the PCM for you.
Matt
Old Oct 10, 2006 | 12:48 PM
stdjsw311's Avatar
ok that is an idea i will try to take it out there this week. does anyone have any other comments
Old Oct 10, 2006 | 01:43 PM
BFate's Avatar
You can find someone who has HP Tuners for your year of car and download a stock PCM program and reprogram it that way back to stock.
Old Oct 10, 2006 | 04:39 PM
stdjsw311's Avatar
do you think it will hurt to run a wet shot 100hp???
Old Oct 10, 2006 | 05:19 PM
02SOMWS6's Avatar
I had a hypertech way back before I did H&C and I lost power with the timing that the hypertech added. You DO NOT WANT TO SPRAY WITH A HYPERTECH TUNE.I dont know how to be any clearer on this. The hypertech tune adds to much timing for spray
Old Oct 10, 2006 | 05:24 PM
02blackta's Avatar
yea man if i where you i wouldnt run any shot at all on the hypertech programmer ...if you do you have a very high chance that you will detenate.. if you bought the car with it in there then you should have been given the programmer .... if not contact the person you bought the car from and try to get it cause if you dont have the exact hypertech it wont work and its a pain to get your comperter back to stock....
Old Oct 11, 2006 | 09:54 AM
stdjsw311's Avatar
well alrighty i will go to the dealership today and see id they can reset my ecm back to stock
Old Oct 11, 2006 | 10:08 AM
Muerte_X's Avatar
Sorta offtopic, but how much power did you lose? Mine picked up HP on a dyno. I'm not sure what the timing is set at with the hypertech.
Old Oct 11, 2006 | 01:37 PM
02SOMWS6's Avatar
way back with stock H&C my car would run 12.6 NA with the hyper tech and 12.3 NA back to the stock tune. Thats going back to 2002. Not sure how it effected power but I know what it did to my time slips. It will work on a stock car but I had a lot of bolt on's headers and gears and it didn't like the extra timing
Old Oct 11, 2006 | 02:17 PM
stdjsw311's Avatar
i went to the dealership today. they want 78.00 to flash the computer i laughed at them so i guess i have to wait til i do my heads and cam then get it tuned to do it.
thanks
john
Old Oct 11, 2006 | 03:03 PM
Muerte_X's Avatar
Ah, I see. Yeah, time slips tell more than just dyno numbers do. My car is mostly stock, converter, lid, cutout, and free mods. Maybe something changes with the headers.
Edit: It also made my car super rich, not lean like I've already read on here. I had to lean it alot after the power programming.
Old Oct 12, 2006 | 05:28 AM
2001z's Avatar
thanks
john
What did you think it was going to cost for free? Wait till you get the tune and dyno bill if you think that is high. Hypertech sucks it is known for making you loose power instead of improving .
Old Oct 12, 2006 | 08:47 AM
BFate's Avatar
This is a free option.
Old Oct 12, 2006 | 09:48 AM
stdjsw311's Avatar
i knew it was not going to be free but damn that is expensive. the dyno tune is only 400 i will be happy to pay that to get dyno numbers and have the car running right!
stdjsw311's Avatar
how do i actually load the program in??
Old Oct 12, 2006 | 12:25 PM
BFate's Avatar
You will need to find someone in your area with HP Tuners for the year of car you have. It is software that will program your stock PCM through the Diagnostic port via a cable. Then all you need to do is go to the .bin repository on the HP Tuners website download a stock .bin for your car (this will be a file) Then just program your PCM with it through HP Tuners.
Old Oct 12, 2006 | 09:40 PM
02SOMWS6's Avatar
Get a hold of the person you brought the car from. The hypertech can only be used on 1 car at a time. So if your car has a hypertech tune in it the hand held programer is useless to anyone but you. It can only be used on your car right now. If he pulls the tune out of your car atleast then he can sell the hypertech
Old Oct 12, 2006 | 09:50 PM
Justg's Avatar
My car gained 1 horsepower and 3ft lbs on the hypertech tune. this done on the dyno back to back less than ten minutes apart. My car is an auto. It detonated so bad before it would shift you could hear it. So I put it back to stock and it stopped detonating. That was way too much to ask for so little gain.
Old Oct 13, 2006 | 12:10 PM
stdjsw311's Avatar
i just need to fine a way to get in touch with the guy
