nos nitrous jetting
Old Oct 15, 2006 | 05:49 PM
pro346's Avatar
Default nos nitrous jetting
hi guys i got a nos kit on a 2001 ls1. It is not the new plate style one, it uses two foggers tapped into throttle body. At the moment i got 50/27 in both foggers and its way too rich. I want to run 150 threw it and being told 63/32 jetting is the way to go, i also run a walbro intank pump if that changes anything. Really want to get well into the tens after running 11.18@122 with old jetting.Any info would be appreciated
Thanks Leigh
Old Oct 16, 2006 | 11:21 AM
Kyle@NOS's Avatar
LS1TECH Sponsor
I want to clarify. Do you have two fogger nozzles with two jets in each? What was the air:fuel with the 50/27? That should have been really lean.
Our jetting for a 150HP on a twin fogger is 46/38 which will be rich for an LS1.
Kyle
Old Oct 16, 2006 | 01:14 PM
srsnow's Avatar
Kyle is right that 50/27 in 2 nozzles would be like running 70/38 in a single nozzle which doesn't seem like it would be all that rich. Which nozzles are you using if they are the B nozzles that might help explain the rich condition. That nozzle tends to be a little restrictive at those jet sizes. I wouldn't recomend using the 62/32 that would be for a single nozzle.
Old Oct 16, 2006 | 06:36 PM
pro346's Avatar
Kyle, yes i have to foggers with two jets in each. I cant remember what fuel ratio was as i dont tune it my self. dont know which nozzles im running, but car has been dynoed and tuner said its very rich.
Old Oct 16, 2006 | 06:46 PM
srsnow's Avatar
Are the nozzles black with 2 small holes in the tip? If you wanted to try the 63/32 you could split it up to a 44/23 which would be equal to the same square area as the 63/32
Old Oct 16, 2006 | 06:59 PM
Robert56's Avatar
For those reading along, the math for calculating changing from known single jets/single nozzle to dual jets/dual nozzles is in the sticky first post on jetting tables. Also, math for going from dual jets to single jets is there.
Robert
Old Oct 17, 2006 | 10:35 AM
Kyle@NOS's Avatar
LS1TECH Sponsor
What solenoids are you using?
What was the bottle pressure?
Kyle
Old Oct 17, 2006 | 10:48 AM
blacktransam's Avatar
Robert
and now back to our regularly scheduled programming
Old Oct 18, 2006 | 06:17 PM
pro346's Avatar
kyle ive found the kit numbers. the kit was suppied to me about a year ago.
117nos nissan 300zx non turbo 1990kit
05000NBnos power shot basic half kit.
They are the two packs i got.
Any way went out the drags last night and ran a best of 11.04 @ 124
only went 98mph at half track had 5 passes on the bottle still looks really
rich. jetting was 63/28. bottle pressure was 1500 on first pass and about 900 to 950 for the next 4.
Old Oct 18, 2006 | 06:36 PM
monza500ci's Avatar
hey pro346.. your fuel pump is putting out 62psi.. and all jetting i have found is setup for 42psi.....that is why it is rich...i run the same setup as you..my 1st stage is fuel 18 nos 38 drops et..3 tenths.....
Old Oct 18, 2006 | 08:06 PM
pro346's Avatar
monza500ci,
i have just ordered some 24 fuel jets and im going to stick with 63 nitrous, going to be a week or two before i can get back to the track for that 10 second pass! thanks for the info its been hard to work out
