Nitrous problems......
Old Oct 17, 2006 | 10:23 PM
CarrotcarZ's Avatar
Default Nitrous problems......
Well i've got the TNT F2 Power ring kit jetted with the 150 pills. I've got a racetronix fuel pump/kit, FAST 36# injectors, cam, bolt-ons etc etc. MY problem is when it hits off the line it feels nasty, on/off the limiter, it hits and then cuts off then hits again. People that saw the car run said it was backfiring and throwing flames out the exhaust during the run. I just cant seem to get a clean pass outta this car. Any ideas what it might be?
Old Oct 17, 2006 | 10:40 PM
bottledls1's Avatar
what plugs do you have in it?
Old Oct 17, 2006 | 10:50 PM
Oso SS's Avatar
are all your grounds good? make sure all the wiring is good and your bottle is facing the right way
Old Oct 17, 2006 | 11:13 PM
CarrotcarZ's Avatar
All the grounds are good, and the bottle IS facing the right way. Im using TR6's......
Old Oct 27, 2006 | 01:40 AM
CarrotcarZ's Avatar
still the same problem....same **** happend last friday......any ideas?
Old Oct 27, 2006 | 11:50 AM
Robert56's Avatar
The on and off thing sounds like a FPSS, are you running one, if so, bypass it then try it again. here's the TNT number For David at TNT: 903 834 1858.
Robert
Old Oct 27, 2006 | 03:00 PM
CarrotcarZ's Avatar
Im a newb when it comes to nitrous robert....what is a FPSS?
Old Oct 27, 2006 | 03:21 PM
Robert56's Avatar
Fuel Pressure Safety Switch. Normally located on the end of drivers fuel rail. I know what you mean, when I go over to the tuning section some of the guys start talking in abbriviations like we all know it all. It's like what the h*ll did he just say.
