Fuel Pressure Switch Installation
Old Oct 21, 2006 | 12:40 PM
nitroman's Avatar
Default Fuel Pressure Switch Installation
Hi, new here, did a search for my question but didn't come up with anything.
I've got a fuel pressure safety switch to install but not sure how - the fuel rail on the LS2 has a little valve on it (like a tire valve) to release the pressure, but the switch nor the 90 degree adapter I'm using has anything to push in the little valve on the rail to meter the pressure.
Am I missing something basic here?
Thanks alot for any help.
Old Oct 21, 2006 | 06:41 PM
Brett H's Avatar
The valve is called a shrader valve. It needs to be removed to do the install. It is unscrewed the same way a tire vavle is removed and the tool for it can be bought at most parts places for a couple bucks. Good luck with the install.
Old Oct 21, 2006 | 11:22 PM
nitroman's Avatar
ahhhhhhh I knew I was missing something, thanks alot!
Old Oct 22, 2006 | 12:16 PM
GTOtoGO's Avatar
Be careful the LS2 fuel rail is kind of weak. A number have been broken scewing a fitting on the port.
Old Oct 22, 2006 | 06:13 PM
nitroman's Avatar
Yeah I've heard about that, thanks for the heads up.
