Stand Alone Fuel Requirements
When using race gas in a stand alone, will i have to change the jets out for a smaller fuel jet than recommended (since the recommendation is for pump fuel)? What fuel is recommended for a 200 dual stage? It seems like most people on this site are running 104+/-. Would anything higher be beneficial or just a waste?
I'm assuming I'll have to tune NA and pull a few degrees of timing, then start tuning on the nitrous/stand-alone and see where the A/F is before the start switching jets if it's recommended?
BTLFEDSS
exspecially for a badass fuel pump to pump 100, 150 or even 250hp (a stock one could handle this power easily)
i dont think a metal tank should be more than 75 bux, i dont see the need for them to be more than 300 bux...
Here are a few pictures of some of our installed in different applications.
This one goes in the fuse area and requires no modifications to install.
This one requires relocating the battery to the back of the car. The stock batter hold downs hold the unit in the car.
This one is for the C5. It tucks down in the nose of the car out of the way.
This is a 3 gallon that goes in the back of the car.
We also offer custom annodizeing or polishing.
We have several other models to choose from and are in the process of adding more.
Check them out here.
http://www.nitrousoutlet.com/catalog...del=73&dept=11
