whats the trick to wiring msd window switch?
I wired mine like the sticky up top said white wire to #10 on ecm,yellow wire to the fpss and also tried the yellow on the wot switch.......I even wired the red wire straight to the battery to see if I could get it to work I also cut the wires so it would read in 4cyl.mode.......... can anyone help please.......It seems it should be fairly simple but I don't guess it is..the one I have is #8956
so the yellow don't hook to the fpss? When you say relay you mean the one that the fpss wire runs to?If you mean the ground side of the fpss...thats were I had it ...could it be something else keeping it from working? I even cut the white wire from the ecm so I was sure I had a good connection for the tach output
Let me put this in just so you'll know........the way I tested it to see if it was working right was I took the nitrous and fuel line out of the bellow held them away from the car and with the car Ideling I arm the system and pushed the wot switch by hand and it shot notrous out the line. If I'm thinking right if the car is ideling and I have a 3000rpm pill in and pushed the wot switch by hand it should'nt haved sprayed correct?
