stock A4
Old Oct 22, 2006 | 10:42 PM
Magnet's Avatar
Default stock A4
sorry, i tried searching but its not working..im wondering how long a stock A4 tranny will hold up under a 100 shot? i'll probly be going with a yank 3600 nitrous conveter too if this changes things..thanks
Old Oct 22, 2006 | 11:17 PM
00formLs1's Avatar
it all depends if you spray thru the shifts. some have gotten away with it for a few years others a few passes. the best thing to get would be a window switch so you don't spray thru the shifts. ur tranny will last longer that way.
Old Oct 22, 2006 | 11:29 PM
Magnet's Avatar
so if i had all the precautionary equipment including a window switch, fpss etc..on a full bolton car with a 100 shot it would last awhile?
Old Oct 23, 2006 | 12:07 AM
00formLs1's Avatar
yea, there sould not be much wear on the tranny when u don't spray thru the shifts.
i have had my n2o for about year and everything is running good. i have 116xxx miles right now.
a tune woulf also be a good idea.
Old Oct 23, 2006 | 11:49 AM
Magnet's Avatar
sounds good...
Old Oct 23, 2006 | 04:39 PM
bjamick's Avatar
not long mine made maybe 3 passes before mine started slipping on a 100 shot. sprayed at bout 10mph and held it until bout 100mph man did it fly.
Old Oct 23, 2006 | 05:10 PM
gillbot's Avatar
Check the trans forums, some say RPM kills the trans long before power level. Read and make a judgement call from there. Personally, I think i'm gonna see how long my stocker will last through my 400RWHP NA motor and a 100 shot on top of that.
Old Oct 24, 2006 | 12:21 AM
Magnet's Avatar
but did you have a window switch and the other safety junk? also i heard 3000 to 6000 is the safe rpm zone, so 10mph seems to soon, but i don't know anything lol...im the one asking the dumb questions
The car only has 19k miles on it so everything is mint condition BTW
Old Oct 24, 2006 | 01:13 AM
1320 killer's Avatar
thanks for the info I needed to know also
Old Oct 24, 2006 | 07:19 AM
BadAssFast's Avatar
I use a 4L60E with Trans Go shift kit, Yank SS3600 Stall and 4.10 rear gears turning 10.5x28 slicks with 600+ rwhp on nitrous. I use an FJO Mini Controller to control nitrous. I also change most all my fluids about 5x the normal daily driver pace. Oil 1000 miles, rear end fluid every 6 month, trans fluid at least 2 x year. I'm going to start using Royal Purple Trans fluid instead of GM. So far i'm still tight. Approx 70,000 miles on transmission. 15,000 miles of it was sprayed with 125-225 shot.
Old Oct 24, 2006 | 09:04 AM
bjamick's Avatar
no i dont have a window switch, i just use a red button that i pull out of my ash tray lol.
Old Oct 24, 2006 | 12:31 PM
Magnet's Avatar
holy crap...is this your stock tranny also is your stall a nitrous stall?? or does blow through it?
Old Oct 24, 2006 | 01:13 PM
BadAssFast's Avatar
SS3600 is a regular Yank converter...I have Nitro Dave's old TH400 in the garage waiting for "the inevitable" I guess...just trying to put off "the inevitable" for lack of 0.7:1 final gear of the 4L60E!!
Old Oct 24, 2006 | 01:43 PM
00formLs1's Avatar
thats what sprayin throu the shifts will do.
i have a fuddle 3500 2.0 str with out the anti balloning plates and so far its been great on the juice.
Old Oct 24, 2006 | 04:01 PM
Todd157k's Avatar
WINDOW SWITCH !!!
and (as stated) start at 3000. (not 10mph.. LMAO) but your upper limit is 200 rpm BELOW shift point. My A4 shifts at 5800 so I shut it off at 5600. I could set the shift point higher with my programmer but I prefer to keep my car in one piece and if that's what it would take to win that race.. well I lost. (but I can still drive home)
Old Oct 24, 2006 | 09:08 PM
nuckifuts's Avatar
Old Oct 24, 2006 | 09:57 PM
00formLs1's Avatar
lol , a window switch is a n2oed auto's best friend. i have mine set to start at 3000 and i have it set off at 5900.
Old Nov 26, 2006 | 07:42 PM
Ls1Envy's Avatar
So how are you guys launching with the spray? Right off idle?
