Progressive Set-up - Starting Suggestions?
Old Oct 27, 2006 | 10:13 AM
bbradyc5's Avatar
Default Progressive Set-up - Starting Suggestions?
I am running a FJO mini controller on my NX wet system with the 150pills in and my TBSS mods are listed in sig below. Any suggestions for starting points on progressive ramp set-up I should start with (keep in mind I'll be staying with street tires for now)???
Old Oct 27, 2006 | 11:05 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
Go ahead and start the controller on 0-100% If running time give it 7 seconds or so. IF the tires hook you have 2 options to get more. Lower the time, or increase your start %.
I like lowering the time my self. Now this is on street radial tires. NOT stickies of any kind.
Now lets say you start to spin at the top of first gear. NO problem just before that point in time you can lower the power level curve and make that area flat. so not to increase power but hold that power for X amount of time.
the really nice thing about this controller is all the options you can do with that ramp.
here are just a couple of examples.
Attached Thumbnails Progressive Set-up - Starting Suggestions?-contolling-wheel-spin.jpg   Progressive Set-up - Starting Suggestions?-straight-run.jpg
