Heads, cam, speed density dry nitrous = 183mph in standing mile!
Old 10-30-2006, 10:30 AM
Chris@NitroDaves
Guest
Posts: n/a
Congrats Patrick... You hit around the MPH that we were talking about. I bet it was fun.
-Chris
Old 10-30-2006, 02:13 PM
Restricted User
Smokin87TA's Avatar
Congrats, that sounds like a blast.
Old 10-30-2006, 02:20 PM
QUASAR's Avatar
Congrats!
Do you have a specific nitrous tune that enables based on nitrous activation?
Old 10-30-2006, 03:24 PM
LS1 Tech Administrator
Patrick G's Avatar
Originally Posted by QUASAR
Congrats!
Yes. With speed density, I made my PE multiplier inactive unless my TPS exceeded 95%. To compensate for a possible lean condition on motor, I added 13% extra fuel to my 90-105KPa VE tables to get them to keep me at 13.0 A/F ratio up to 95% TPS. This mimicked my NA tune as my VE tables were tuned with my PE multiplier being locked in at 1.13. At 95% TPS and above, my PE multiplier is 1.30 (adding 30% more fuel). So under 95% TPS, I'm at 13.0 AFR N/A in my 90-105KPa VE tables, then as soon as I'm at 95% TPS or higher the extra 1.30 PE multiplier kicks in. Basically, the fuel is already there by the time the nitrous hits (at 100% TPS). No delays. It hits harder than a wet shot (since wet shots can have lean spikes too).
Here's how I did it:
Let's say that my NA tune has my VE table peaking at 115% at 100KPa and 103% at 90KPA. Well this is based on my PE multiplier of 1.13. When I zero my PE multiplier for anything below 95%, it leaves the VEs on the lean side from 90KPa and greater. To compensate, I add the 1.13 back to the 90,95, 100, 105 VE numbers. Now my 100KPa VE table peaks at 130% and my 90KPa table peaks at 116%. So now, up to 95% TPS, my tune is exactly like my NA tune.
But when the TPS exceeds 95%, it adds the 1.30 PE multiplier to compensate for the nitrous that hits at 100% TPS. The 1.30 multiplier seems to work well with the .065 jet at 1050 PSI.
Special thanks go out to Geoff from Thunder Racing for giving me the idea.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old 10-30-2006, 10:55 PM
Patrick G's Avatar
Video clip added:
http://guerragroup.com/PG-TxMile10-28-06_183.092mph.wmv
__________________
Old 10-31-2006, 06:00 AM
Reject's Avatar
sounds badass!
Old 10-31-2006, 07:41 AM
QUASAR's Avatar
Nice job! I have always theorized about setting something up similar to that, and wondered how it would perform. I'm glad someone finally did it. I guess as long as you stay under 95% throttle N/A you won't flood the motor with the 1.30 multiplier. What do your logs look like in terms of the instant you go wot, how does the afr react? Is there a moment where it is pig rich or is the timing of the nitrous pretty dead on. I would think even if there is a small discrepancy it would be neglegable seeing wet shots have a traditional momentary lean spike anyways and it doesn't hurt anything. But I was just wondering. Again good job on that setup.
Old 10-31-2006, 11:48 AM
Patrick G's Avatar
The beauty of the speed density tuning is that the fuel arrives at the same time as the nitrous. There is no lean spike. It hits very hard!
__________________
Old 10-31-2006, 02:03 PM
BLCK PRL's Avatar
http://texasmile.com/
Old 11-01-2006, 11:29 AM
QUASAR's Avatar
Just thinking out loud, what about some sort of setup where when you go WOT N/A, you cap TPS voltage to whatever = 95%. And when the nitrous gets activated the tps runs thru a different circuit without a cap and can report the full 100%?
Old 11-02-2006, 07:25 PM
Patrick G's Avatar
That could work, but it's a lot more complicated than some of the other simple solutions out there. The best I've seen is EFI Live custom operating system 5. You get the timing retard and fuel ramp-up needed to run hard and safe with nitrous.
__________________
Quick Reply: Heads, cam, speed density dry nitrous = 183mph in standing mile!
