Full bottle preasure?
I'm new to this game, I've had my system installed since aug. but for various reasons haven't to spray it other than the dyno. I installed a preasure gauge, and I'm ready to push the button to see what the hell this thing does on the streets. I know I need to turn my bottle warmer on and get it close to 950PSI. MY bottle only made 2-3 pulls on the dyno, so it's probably not empty and right now it's showing 350PSI. Is this normal for a semi full bottle. Will my heater raise the preasure that much?
thats not normal at all... my bottle, whenever i get it filled is normally 1200-1300 PSI at least, and doesnt go much below 900 until its empty. So i would say your bottle is empty
Dang dude.. how much did they use when on the dyno? NO, 350 is not normal for anything.. other than time to refill. Weigh your bottle and check the label for weights. That will tell you how much you still have in it. Just don't spray at 350 psi.
Well the biggest part of that I'm sure leaked out when my bottle nut went bad.
I was curious as to how much had leaked...so I guess most of it. So I guess I'll just have both bottles filled when I head to the track in 2 weeks.
