Psi question
Old Nov 2, 2006 | 02:43 AM
BuBbABFP's Avatar
Default Psi question
Hello guys! i have a question on psi.... Ok i had my bottle filled about a 7-8 days ago(first time) pressure started at about 950 or 900 used it a couple times.. found out 2 nights ago that my bottle was leakin through the gauge and the little blockout fiting on the other side.. so it was leaking ever since i got the bottle filled(not much but when soap and water added u can see quite a few bubbles) so i got the problem fixed and the bottle pressure was about 600 psi, the bottle wieghs in at about 12 pounds.
I installed my heater tonight and got it to heat up like crazy it got super hot and the pressure got up to like 750.. u guys think it didnt climb to 950-1000 due to the bottle being almost empty? btw its a 10lb bottle.
thx
Bubba
Old Nov 2, 2006 | 06:01 AM
nate-roth's Avatar
A 10lb. bottle weighs about 14.5lbs empty and 24.5 when full. However I usually fill them until the weigh 25.5-26.0lbs. I think it's time to refill the bottle and get a more accurate scale.
Old Nov 2, 2006 | 09:20 AM
mrdragster1970's Avatar
6 & 8 Second Club
Exactly^^^^^^
Old Nov 2, 2006 | 06:32 PM
BuBbABFP's Avatar
thx guys! if its empty wil it still show Psi? im pretty sure its empty because i think it weighs in at about 15lbs. il check tonight though.
