What all does it take to run 2 bottles?
Old Nov 2, 2006 | 05:56 PM
blackls6's Avatar
Default What all does it take to run 2 bottles?
Alright I already have 1 10lb bottle with a bottle heater. I would like to run another 10lb bottle as well. What all will I need to do this? I know I will need another bottle of course...But will I need another bottle heater? Also, what fittings do I need to link the two bottle together? Also, what can I use to make the blow down tubes run together? Also, will I need another remote bottle opener to open both bottles at once? Thanks.
Old Nov 2, 2006 | 06:10 PM
mrdragster1970's Avatar
6 & 8 Second Club
I use 2 bottles, I run 2 heaters, 2 blow down lines, and we are not allowed remote openers, so I don't know if you can plumb both in to one opener. I use a y-block mounted to frame and run one line up to motor. I guess if you wanted 1 blow down you can use another y-block, I don't use tubes, I use hose.
Old Nov 2, 2006 | 06:22 PM
ChrisUlrich's Avatar
How much more difficult is it to run 2 of everything? Does it get costly? I kinda want to run a 10lbs and a 5lbs hidden somewhere.
Old Nov 2, 2006 | 10:31 PM
blackls6's Avatar
Thanks for the help. Yeah I would imagine it would get costly.
Old Nov 3, 2006 | 08:14 AM
6 & 8 Second Club
My car is a legal Pro-Modified, it was built for 2 stages, and has a dual holder.
All I did was remove one line and added a y-block, to save weight, less chance of leak ect. I have 10 bottles already, so it didn't cost me much. I had to buy 1 more heater.
Old Nov 3, 2006 | 09:14 AM
Nitro Dave's Nitrous Outlet's Avatar
I run dual 10lb bottles in all my cars. I do not like 15lb bottles.
You will need two sets of bootle brackets, Two bottles, a Y connector and two hoses to go from the Y to the bottles.
I suggest dual heater elements. You can use one pressure switch.
Dave
