FJO Mini Problem
Old Nov 7, 2006 | 05:02 PM
barkingspud's Avatar
Default FJO Mini Problem
So,
This install is on a 2005 GTO LS2. The controller works flawlessly except for a strange problem. When the system activates my speedometer dies. I'm pulling the RPM signal right off the green wire by the passenger side center coil packs. When I let off the pedal, the speedo comes back. Tach works fine the entire run. Anyone??
TIA,
Mark
Old Nov 7, 2006 | 05:09 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
Where are you pulling power from?
Old Nov 7, 2006 | 05:12 PM
Todd157k's Avatar
Is this how you have it wired?
http://www.nitrousexpress.com/Images/fjoclutch.jpg
Old Nov 7, 2006 | 05:14 PM
NXRICKY's Avatar
You have a clutch swith in this car? WHere are you pulling power from? What wires do you have connected to the Cars wiring.? and where are those connections.?
Old Nov 7, 2006 | 05:15 PM
Originally Posted by Todd157k
Yep....I'm an A4 so, no small red wire needed (Clutch Switch) ....All the leads are as short as possible and in fact I have the controller mounted right next to the fusebox that is right next to the battery. Everything is grounded to a ground source right next to the battery. The FPSS is grounded to the body by the ECM. Oh and I'm pulling power directly off the positive battery terminal through a 30amp fused connection
Old Nov 7, 2006 | 05:28 PM
Todd157k's Avatar
FPSS is not a power / ground switch. It's inline (series) switch. Shouldn't be hooked to chassis unless the other side is hooked to relay chassis ground connection. Not a good idea. Pulling too much current through FPSS.
The question of where you're tapping for power is the switched 12v.
Old Nov 7, 2006 | 05:36 PM
Switched as in for the arming switch? I'm pulling power from an unused 30A circuit for the smokers package.
Old Nov 7, 2006 | 05:41 PM
So....Where should I be grounding the FPSS???
Old Nov 7, 2006 | 07:33 PM
gillbot's Avatar
depending on how your system is wired, it shouldn't be grounded.
Old Nov 7, 2006 | 07:46 PM
Todd157k's Avatar
Do you have the other side of FPSS going to pin 85 of the relay? If so, it's wired ok. If not, tell us how you have it wired.
Old Nov 7, 2006 | 08:29 PM
Yep. Pin 85 is for the FPSS and the other terminal on the FPSS is to ground. The system is working fine with the exception of my speedo issue...Sounds like it would be something related to the RPM signal connection......
Old Nov 7, 2006 | 09:32 PM
Todd157k's Avatar
ya. I agree since it only happens when the FJO kicks in. So, ya need to check that pick up you're using. I don't know which is the correct wire for the GTO but doesn't sound like it's the one you're using.
Old Nov 7, 2006 | 09:40 PM
Nitro Dave's Nitrous Outlet's Avatar
It deffinly has to do with a connection somewhere.
Tach signle should be comming from passenger side coil trigger wire light green.
Dave
Old Nov 7, 2006 | 09:49 PM
Dave
Yessir...It is connected to the light green wire passenger side. I've tested the system and it is picking up the signal properly. To test it, I set the FJO trigger for 1500rpm's disconnected the selenoids from the relay had someone rev it and the led's on the FJO tell me it's working just fine. Hmmmm.
Old Nov 7, 2006 | 09:56 PM
hmm, Try pulling the accessory hot from another area and see if that is the problem.
Dave
Old Nov 8, 2006 | 09:01 AM
NXRICKY's Avatar
One thing is if your FJO box is near something sensitive. The RF noise traveling on the main ground wires is pretty high.
Light Green.
Tell you what with noids UNPLUGED see if the SPEED O drops out. If not it has to do with ground and noise. IF it does might be time for a rewire.
Which TPS wire did you plug on to.
Ricky
