Help with nitrous activation.
Old Nov 8, 2006 | 07:37 AM
1fastz28nx's Avatar
Default Help with nitrous activation.
I just recently converted my Z28 to a M6 car. I've run nitrous on my car for 2 year with an auto in it. I just ran a WOT switch with a master activation switch inside the car. With my new setup I still want to run a WOT switch, obviously, a window switch and I have a cue ball shifter **** with a button on it.
What is the best window switch to get? Should I get a MSD window switch and have a micro switch on the throttle body or should I get one of the FJO mini controllers that will activate off the TPS sensor output?
Thanks in advance for the help.
Old Nov 8, 2006 | 08:27 AM
Firechikn's Avatar
The programable FJO looks pretty sweet. I run the 2 stage controller from Dynotune
(you can run a single stage too). It has tps, 2 window circuits, and gear lockout. Its plain and simple, and the best part, its cheap.
Old Nov 8, 2006 | 03:19 PM
1fastz28nx's Avatar
Ok, I'll check it out.
