Would you do boost if you could?
Having said that, I'd do s/c or t/c on my truck in a heartbeat. It could use a good 'push' all the time. "Pushing" a hemi means killing most cars.
but really n2o is a great way to get power. you cant just drop a turbo kit on have a tune and be done. there is normally a lot of time after trying to iron out all the bits and bobs.
buutttt i still think having it there all the time, and for as long as you want is a big advanage! you dot have to use it but it is just a right foot flex away!!
just my thoughts
Chris.
It would be nice to go FI and nitrous, if you have the money go ahead and spoil yourself I guess.
how does 700lbs ft from 2000rpm sound and over 800lbs ft at peak (well its more of a flat line to be honnest). but then hes spend three arms and two legs on the car and motor!
thaks Chris.
and your right, n2o gives the FI guys a good fight! and we all know every method of getting more power has its disadvantages!
thanks Chris.
buutttt with your n2okit you could make sure the boost is very very cold!! hehe
thanks Chris.
If I had a big budget & there was a turbo kit that fit nicely without moving/removing accessories, I would go turbo.
Why? cause FI is there all the time & the only thing you have to fill is the gas tank. On the other hand, for those of you that are not rich(like me), I would rather spend the 6-7K on a long block & add N20 later & feel comfortable knowing I can go just as fast on spray. The thing is with spray, you should only use it when you really need it, or testing it. Driving around with an empty bottle makes the whole system pointless.
I thought about going FI but by the time Ill be able to afford the kit + forged engine + everything else Ill be too old to drive. Besides, just watching this vid makes me wanna stick with N20. I know this set up Is not a ton of money, yet look how fast it is...
http://video.ls1tech.com/search/nitr...ec5114c892.htm
