bottle pressure
Old Nov 13, 2006 | 12:15 AM
daniel6718's Avatar
Default bottle pressure
figured out the problem with my motor popping on the n20 was low pressure, so im at the 1/8 tonite and i got it up to 1000 hit it, smoothe pulling great and as soon as i hit 3rd gear it started popping again, very faint,look at the bottle psi after the run and it was 650-700?
next run i brought it to 1100 (wooried about it being lean bc i think the jets are rated at 950??? (HSW KIT)
did the same thing on the big end...was about 750 after the run...is it normal to lose about 350psi during a run? bottle was on a new fill, custom 11.5 pounds in it...
anything i can do to prevent this besides 2 bottles?
also i have no heater we were using a car heater to heat it, will a bottle warmer help this during a run?
Old Nov 13, 2006 | 02:06 AM
BuBbABFP's Avatar
hmmm... 350!! thats a lot of psi to loose from 1 run! Mine never goes down that much, but then again i got an auto bottle heater set to 1k psi.
Old Nov 13, 2006 | 10:00 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
when you heat a bottle, you need to bring it up to temperature slowly. The more unifor you heat the bottle, the longer it will hold temperature. Also you might want to invest in a bottle blanket...or just through a coat over it. I am running a heated bottle bracket and will heat the bottle for 30-45min before running. On a 100-150 shot you should not have a problem with pressure drop.
Also over filling the bottle will also increase pressure drop. If you are running a 10# bottle ...put 10#s in it.
Old Nov 13, 2006 | 12:02 PM
daniel6718's Avatar
ok thanks...we were sitting it on top of the motor between runs, took about 10-15 min to warm up to 1100, im waiting for my dynotune heater to get here....i hope that will keep the whole bottle warm and help...
thanks
Old Nov 13, 2006 | 12:06 PM
srsnow's Avatar
Did you say they put 11.5 pounds in it? If so that is why it dropped so fast. In fact I know of people that under fill them by about a half pound and seem to get better results than if they were full. Also the higher pressure you start with the faster it will drop.
Old Nov 13, 2006 | 12:15 PM
Todd157k's Avatar
More fill = Less pressurized volume.
Ever use a pesticide sprayer? if you fill it half way, it takes a while to pump up the pressure, but lasts a looong time.
Old Nov 13, 2006 | 01:36 PM
NHRATA01's Avatar
Beat me to it. You need to have enough pressurized gas at the top of the bottle to force the liquid through the dip tube and out of the nozzle.
Old Nov 13, 2006 | 08:23 PM
daniel6718's Avatar
gotcha...ill keep thta no good fool friend of mine from filling it again
