Switching to WET have Qs
370 Iron forged ~11.75 SCr and ~8.65 DCr
I have a few questions, I want to shoot 150:
1- What plugs do you recommend, would TR6 be enough or should i switch to TR8 (no TR7s to be found here)
2- I researced that 12.5/12.6 AFR is a good ballpark, but that is on the shot. What NA AFR do you recommend, currently at 12.8?
3- Using 98 Octane fuel, can mix a bit of race gas yes/No?
4- Currently running 5177 dry 4an line. Can a 6an line hook up to the NOS bottle or the bottle fitting needs to be changed?
5- I'm assuming the plate kit comes with a 6an main nitrous feed line correct?
Thanks,
Mark
Our plate kits can be ordered with either -4 or -6 feed lines...standard is -4
