Progressive Controller BLOWOUT SALE
Old Nov 15, 2006 | 12:50 PM
NitrousDirect's Avatar
Default Progressive Controller BLOWOUT SALE
BRAND NEW FROM COLD FUSION NITROUS SYSTEMS.
We have been given special pricing and are passing to DIRECT to you guys!!
For a limited time this SWEET new controller is only $199!!
This unit was designed to allow the aggressive use of nitrous power and putting it on the ground. A simplified wiring harness and easy to adjust push button LED controls makes this device a breeze to install and use.
The start percentage can be adjusted from 1% to 100% in 1% increments. The Nitrous build time can be adjusted from 0.0tenths (instant 100%) to 8.0 seconds in 0.1 tenths of a second increments. It also has 2 modes for automatic cut off or continue the count down. It is activated by your WOT switch or your push button switch that activates your nitrous kit.
The high amperage drivers can handle all of today' high amperage solenoids. Infact, this controller is so heavy duty it can control 4 large PRO solenoids used on a V8 FOGGER KIT!!! Overall dimensions are 4?x3?x 1.75?. Shop around and you will find that this is the best deal on the market today! This device is perfect for your nitrous installation and is a must have if you are running shots over 50HP for your engine's safety and longevity. The "hit" of nitrous is what damages components and what has given Nitrous a bad name, but with this heavy duty digital controller you won't have to worry about any of that.
Old Nov 15, 2006 | 04:39 PM
flash12t's Avatar
how long is this sale going to last. .
Old Nov 16, 2006 | 07:51 AM
JoeyGC5's Avatar
Ditto
Old Nov 16, 2006 | 09:00 AM
ALBERT@COLD FUSION's Avatar
I believe it will last until Christmas
Old Nov 18, 2006 | 04:57 PM
Yup but get them while they're hot! and check our other specials in the specials thread you can find in our sig
Old Nov 18, 2006 | 05:32 PM
silverZ98's Avatar
how will this work on a 6speed car? like will it rest it self when you switch gears? or will it pick up from where you left off and once maxed stay there threw the rest of the gears?
like say you got from 50% to 100% in like 5 sec's and say in frist gear it makes it ot 70% then you shift will it go back
to 50% or will it start back at 70% and climb to 100% and hold it threw rest of the gears untill the system is dissarmed.
