View Poll Results: To flycut or not!!!!
Fly cut pistons.........nitrous shouldn't be a problem.
1
50.00%
Don't fly cut pistons.
0
0%
Fly cut pistons even if nitrous will be a problem.
0
0%
Don't fly cut pistons, go with a different cam.
1
50.00%
Voters: 2. You may not vote on this poll
To flycut pistons w/ nitrous or not!!!
I have someP&P, milled LS1 heads with bigger valves and a medium sized cam. My heads have been milled to 63.5cc to acheive 10.8:1SCR. My current cam specs are 228/228 .571/.571 w/ 112 lobe sep.
I want to go with the MS4 cam and keep my worked heads. But to do so I think I would need to fly cut my pistons.
I also have a wet plate nitrous system spraying 150shot right now. I'm in the works of jetting and tuning it to spray 200shot.
Do you think the pistons will be weakened to the point were I shouldn't do the piston flycutting? Or do you think the pistons will be okay?
