175 shot + stock block?
Old Nov 16, 2006 | 07:12 AM
dubrado's Avatar
Default 175 shot + stock block?
Will the stock block hold a 175 shot?
Bout to put a new fuel pump in the goat and wanna up it to atleast 150....maybe 175 if it's safe
I have a 224R cam and bolt ons right now.
thanks
Old Nov 16, 2006 | 10:12 AM
Somebody09's Avatar
Mine was ok with stock heads and cam.
Old Nov 16, 2006 | 11:02 AM
brad8266's Avatar
It will take it provided that fueling is all good and you dont run lean.
Old Nov 16, 2006 | 12:32 PM
00Vette's Avatar
IMO, the stock bottom end is only good to around 600hp plain and simple. If you have supporting mods that increase your 175hp shot to around 600hp out of your cars motor..............I'd back off the spray. But if you have all the safety equipment (FPSS, window switch, etc.) and are below 600hp...........your good to go!
That's just my opinion! Good luck!
Old Nov 16, 2006 | 12:39 PM
dubrado's Avatar
I'm at 470 w/the 115 shot
I was debating on doing the 175 if it would handle.
Old Nov 16, 2006 | 12:58 PM
cjg454ss's Avatar
430whp at least on my short block. getting ready to hit it with a 200 wet with a standalonefor starters. i would do a 150 and not think twice
Old Nov 16, 2006 | 10:10 PM
dubrado's Avatar
I guess I'll do 150 and maybe buck up to 175 when I get injectors
Old Nov 17, 2006 | 02:07 AM
HD1911's Avatar
grow some nuts and throw a 200 at it...come on
Old Nov 17, 2006 | 01:25 PM
dubrado's Avatar
naw, i'm a *****
Old Nov 17, 2006 | 02:16 PM
HD1911's Avatar
haha lol, its all good
Old Nov 17, 2006 | 07:20 PM
Robert56's Avatar
I do a 170 outa the hole on 1st stg, stock block. Unless you are doing a dry hit, (or need injectors n/a) the injectors have nothing to do with it. So, get the info for what you may be doing sorted out, and your 175 is very doable as long as tune and fuel are right on.
Robert
Old Nov 17, 2006 | 09:04 PM
00Vette's Avatar
You should be okay with a 175hp shot! But I wonder if your kit is rated at the wheels or at the motor. Different kits differ in the way they advertise hp.
I'm close to spraying a 200hp shot on my car. I think the car will be fine as long as I don't spray it all the time.
Old Nov 18, 2006 | 01:11 AM
Drew778's Avatar
I've sprayed a 175 shot on my stock block, just make sure you lower the spark (22*)and your fuel system can handle it and you'll be fine.
I also sprayed the 175 and forgot to lower the timing(28*), melted my block and head between 5 and 7 cyclinder.
Just take it up slow and keep checking the plugs and GOOD LUCK
Old Nov 18, 2006 | 09:18 AM
dubrado's Avatar
I don't have a kit though...it's put together with parts I salvaged and borrowed.
I'm cheap
Old Nov 18, 2006 | 03:00 PM
_JB_'s Avatar
I sprayed 150 no problems, then tried 175 had no problems.
Old Nov 19, 2006 | 08:45 AM
mrr23's Avatar
as of yesterday, on the dyno, my stock motor is holding up to a 193 rwhp shot.
