200 shot gonna work?
Old Nov 16, 2006 | 08:10 PM
bearcat's Avatar
Default 200 shot gonna work?
i have an lt1, racetronix pump and harness, je pistons, eagle i beams, stock crank, studed 2 bolt mains. i dont remember what rings i have or what i gapped them at, id have to look. but regardless i think i should be ok for a wet 200 shot, anyone have any input for me? thanks
Old Nov 16, 2006 | 08:16 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
What is your timing set at...or how much are you going to retard (4-8*)
Also what plugs are you running (NGK-8's)
Old Nov 16, 2006 | 08:39 PM
bearcat's Avatar
nothing as of yet, im still learning a bit about how it needs to be setup. the motors still on the stand awaiting its new home but should be in very soon. i do have another walboro i could put in to run 2 intank if you think its neccesary. any info ya got for me would be appreciated. thanks
Old Nov 16, 2006 | 10:03 PM
dlc1609's Avatar
although i'm ls1, i'm in the same boat. stock crank, scat rods, forged pistons. i'm most likely gonna throw a 200 shot at it so if we blow up with that, at least we won't be alone.....
Old Nov 16, 2006 | 10:12 PM
tuff's Avatar
8 SEC SLOPPY SHOT!!!
A 200 shot is pretty safe with the right setup timing ect.Thats like a 25 shot on a honda
Old Nov 16, 2006 | 10:51 PM
1QuickT-A's Avatar
very good example!!! and yeah.. a 200 shot will be fine on either of you guys motors as long as the tune is correct and using good plugs!
Old Nov 17, 2006 | 02:05 AM
HD1911's Avatar
werd, stock ls1 w/ racetronix pump and kickass tune, NGK BR7EF with a 200RWHP shot and it is wicked; i have already gone thru like 12 bottles
Old Nov 17, 2006 | 09:35 AM
Robert56's Avatar
Just watch out for leaning out on the top end, may need a return/reg at the rails. I run 22* of timing and 104 trick gas with tr6 at .035 and runs great and racetronics pump/reg-return at rails.
Robert
Old Nov 17, 2006 | 11:02 AM
HD1911's Avatar
Robert, what is this Reg/return piece you speak ok?
Old Nov 17, 2006 | 12:06 PM
algws6's Avatar
the 97-98 vettes came with the regualtor mounted at the front of the car vs. at the back of the car. so robert converted his fuel system. robert, do you run a BAP?
Old Nov 17, 2006 | 12:44 PM
Robert56's Avatar
No bap, and running a 250rwhp currently. The return and the regulator is at the fuel tank in our cars. This leads to fuel supply issues for some of us (check current thread with dyno sheet) at high demand areas. the reason is, say you have a nasty lean spike, what's happening is your pulling more from the rail faster than it can refill. This is because by the time the reg at the tank reads drop in pressure and re regulates you've gone lean. Now if you do this at the rails, then you have max pressure and supply right there and when rails need refilling they are refilled instantly rather than having a lag time. This scenerio also can happen at the top end high demand area and cause leaning out of higher rpms. Cured all my problems.
Robert
Old Nov 17, 2006 | 12:45 PM
HD1911's Avatar
how hard is it to install, and what parts would u need?
