Nitrous kit im buying
If you do have the bottle Brackets then get a heater only.
http://www.dynotunenitrous.com/store...p?idproduct=17
You will also want a window switch to activate the system through your desired spray RPM (3000- XXXX).
http://www.dynotunenitrous.com/store...?idproduct=194
Does the bottle have a gauge? You will want to have an idea of how full the bottle is (weighing it is another option).
DynoTune, Nitrous Outlet, HSW, and Nitrous Direct are all Nitrous Sponsors check out what they have for the above accessories.
Dry kits on LT1's are not as simple as they are on an LS1's. Unless its a LT1- specific dry kit with fuel pressure booster.
I'd reccomend doing a little more research before you go that route.
Vinny
and also with a window switch...do you really need it? I plan on going from 2nd gear WOT to 80 right before it goes into 3rd and let off
My reccomendation is to run the wet shot with the WOT switch and a button in-line like you described. That will work just fine
Vinny
Hook it up whatever way you want.
If price is a factor and you can not afford to do it right odds are you can not afford to replace the motor either.
On a LT1 I would add a wet system.
With a window switch..
The NOS dry kit will work as long as it has the FMU and fuel pump.
Dave
Make sure the dry kit you are using has the FMU. And make sure you have enough fuel delivery..
All I can do is give you suggestions to kepp you from becoming another guy saying Nitrous blew my motor.blah blah blah. Takeing and useing the advice is up to you.
Im not trying to be harsh. Im just trying to help you out.
Dave
Or...just go to the car and light the engine on fire...it will be quicker to destroy it that way.
Dont be hard headed. Do it right or not at all. You sound young...this is a lesson you should avoid learning the hard way.
The pieces you need are probably not all that expensive and dont add too much to the install and can be likley used with what you have.
But...go ahead and give Nitro Dave or one of the other sponsors a call on monday...it may be cheaper than you think for the parts. Only one way to find out right?
