New B Question
Old Nov 19, 2006 | 08:13 PM
marthastewart's Avatar
Default New B Question
When you activate the system do you need to hold the button down for the desired amount of time you want the spray to come out or does it just take 1 press for 100 hp to flow (if you had a 100 shot nozzle)?
Is it possable to hook it up to so you flip one switch that activates, opens bottle, and sprays it when it hits the desired preset rpm?
Sorry for the stupid AZZ questions, believe it or not I did use the search button which answerd the other 187 questions I had, could not find these answered.
TIA
Old Nov 19, 2006 | 09:54 PM
mrdragster1970's Avatar
6 & 8 Second Club
You can build a circuit to do just about anything with relays, timers, triggers ect.
I would never use anything but a momentary switch to trigger N2O.
I also always use a W. O. T. switch as a back up.
Good luck.
Old Nov 19, 2006 | 11:02 PM
gmpower's Avatar
You need to hold the button.
You need one switch to open the bottle (kit is +$200), one to arm, or a window switch to come on and off and dersired rpm.
Old Nov 20, 2006 | 11:52 PM
JonSS_Tex's Avatar
I would use a wide open throttle switch and some sort of RPM activated switch like the MSD window switch. I used the MSD window switch that requires modules to turn the nirous on and off, but I have heard that the digital one is alot nicer. As far as the activation switch...I installed the nitrous outlet switch panel that fits in the ashtray and includes the purge, bottle heater and arming switch.
Old Nov 21, 2006 | 12:14 AM
I dont want it to be seen so I was thinking of putting another fog light button up top (in the empty slot next to the fog light switch) and putting the activation button in the cigarett lighter spot (remove that, I dont smoke anyway).
