What's the Main Killer?
Old Nov 26, 2006 | 07:31 PM
Demon_Speeding's Avatar
Hmmmm, I think my plan is starting to come together. Next said his won't come with sensors. What kind of O2 do I need and what's the average cost? I am getting quite excited about this. Makes me feel alot better about running the jug on my car.
Old Nov 26, 2006 | 07:57 PM
calongo_SS's Avatar
Seems like you got everything covered. The main killer is probably detonation, but the #1 root cause of killing an engine w/ spray is definaltley user error.
Old Nov 26, 2006 | 08:26 PM
terry s's Avatar
If you are not running leaded fuel the S020004 sensors will work fine. I paid $71.75 ea. To get the most accurate reading the 02 sensors need to be ahead of the cats if you have them. The instructions will tell you how far to to put them from the exhaust valve. If he does not have them you will need the bungs to weld on for the sensors, but they are not expensive. I made my own because the Z has double wall pipe ahead of the cats. I think I still have the new ones that came with it. Hint-drop a big bolt with a washer on it through the bung when if welding with a mig or arc welder to keep from getting spatter on the gasket surface.
I got my stuff from Dave @ Nitrous Outlet. Does his set up come with the gauge?
You will love the peace of mind you get with this unit when spraying. I have an LED in my pod that is wired to the solenoids. I can see exactly when the solenoids have power and when they do not. The unit has shut the nitrous down for being beyond the AFR paramenters I set and I never saw the AFR get out of range on the guage. Things happen so fast you cannot catch it by watching the guage. Don't get me wrong. the guage is great for seeing what the AFR is doing but the FJO samples many times a second and there is no way you can react that fast. I have mine set where if it is out of range for more than .3 seconds it shuts the nitrous down.
Also you can put the control unit most any where you want because it is weather proof. I wanted mine inside though. I put it under the pass. seat. It is out of site but easy to get to. I did have to get longer 02 leads though. The ones it comes with are 4 ft. long. I bought 2-8 ft. ones. But I did not know you can hook the 4 ft. ones together and make an 8 ft., one from two 4 ft. ones. If you need longer ones let me know. I have the two 4 ft. ones that are brand new.
Old Nov 26, 2006 | 08:35 PM
terry s's Avatar
I agree but add to the causes part failure such as the fuel pump. A plugged fuel filter (user error) will kill it in a heart beat (the FJO will catch a weak fuel pump or plugged fuel filter).
So will a stuck open nitrous solenoid (one thing the FJO will not save you from). But if you have a good nitrous filter and have good quality solenoids and do preventive maintenance on the solenoids this is a very rare occurance.
Old Nov 26, 2006 | 08:41 PM
I'll have to check on his setup if it comes with a gauge or not. Thanks again for all your help!
Old Nov 28, 2006 | 10:52 AM
Well, I picked up next's FJO wideband setup. It should be on it's way todayor tomorrow. Now I just need to get my heads, decide on a cam and pick up a nitrous kit... Well and a fuel pump and a few safety items as well.
Old Nov 28, 2006 | 11:12 AM
terry s's Avatar
Good luck. I think you are going to like it.
Old Nov 28, 2006 | 03:03 PM
Thanks terry.
