Nitrous Blows Up My Motor
Dave's money maker kit with with 70 nitrous jet and 36 fuel jet.
FJO nitrous controller with wot switch and window switch from 4000-6000 rpms and it progresses 100 shot at 4000 to 150 shot at 4500. I had first gear lockout turned off because I was running slicks. I know both wires were setup correctly because the lights on the controller light up at the correct time. I know both solenoids work because I closed my bottle and did a short run and the fuel solenoid does squirt fuel into the intake.
NGK TR6 spark plugs gapped at .038".
4 degrees of timing pulled.
FJO wideband controller with lean/rich cutoff wired into nitrous controller. Cutoff is 12.0:1 and 15.0:1
Running 93 octane from BP. Stock fuel pump. I have a fuel pressure gauge and it dropped down to around 52 psi.
What mods to your engine. I used the same kit but with internal work and never broke anything other then a plug or 2. lol how many miles on your engine?? Sounds like you took out a piston. You ever put it on the dyno and look and see what the AF is?? Now i kinda ran into the same problem, but did not blow up, cause we found it on the dyno and shut it off before it blew up. It was my mistake, but where do you have the grounds for the sol and the FJO driver?? you will need something able to hold a 80amp draw. when i moved my ground to the chassie ground i was able to make it work. If not it would not spray correctly. LAst what was you bottle pressure?? what injectors you have and what fuel pump??
i had oil in the exhaust and i pulled the passenger head off and #7 was chipped.
its just one of those bad things that happen, just an excuse to make it better
Perhaps 10.5-12.5 would be a safer setting for the spray?
Stock fuel pump.
Nitrous didn't Blow Up your Motor (imho).....................
adding a nitrous kit and NOT addressing your fuel system blew your motor- get it right.
EVERY SINGLE PERSON I KNOW that has popped a motor on the jug did it because they neglected their fuel system.
$350 for a racetronix setup....... or $3500 for a new motor....hmmmmmm
tough choice if ya ask me.
good luck on the rebuild hopefully you've won some money with that money maker! lol
Was it professionally tuned? Professionally installed? Any advice for a new guy to nitrous like me?
