Purge Solenoid
does anyone here run a relay for the purge soleniod to run higher voltage. as i am having a problem getting the solenoid to open at high bottle pressure. i dont think this would eat the solenoid but i thought id post before i continue
Chomper
If you are using a large Nitrous solenoid for the purge it needs a relay.
What solenoid are you useing?
Dave
Robert
Chomper
yep.. I've got first hand experience at this one. LOL.
Robert
Robert
what is the best way to keep the noid cooled down?
i thought tappin the purge letting the juice chill it down was the proper method?
what do u do about fuel noid that are near the hot motor? any worries?
Dave
Robert
When NX went to the new lightning we had some issues with there first batch. NX quickly changed back to there 063 orfice and coil combination and the problem was gone..
I have seen more problems with the companys useing the 078 orfice solenoids in there kits and there purges than anyother solenoid. Its really just this solenoid combination.They are finiky and problematic.
You have to look past the actual body size and understand the combination as a whole
Dave
Dave
On the small orifice noids I concure and can back it up from actual use.
Robert
